주요 콘텐츠로 건너뛰기
Dell XPS 15 9530 WiFi Card Replacement
필요한 것
  1. Dell XPS 15 9530 WiFi Card Replacement, Base Cover: 1 단계, 이미지 1/3 Dell XPS 15 9530 WiFi Card Replacement, Base Cover: 1 단계, 이미지 2/3 Dell XPS 15 9530 WiFi Card Replacement, Base Cover: 1 단계, 이미지 3/3
    • Using a T5 Torx screwdriver, remove ten 3mm screws.
  2. Dell XPS 15 9530 WiFi Card Replacement: 2 단계, 이미지 1/2 Dell XPS 15 9530 WiFi Card Replacement: 2 단계, 이미지 2/2
    • Lift the plastic tab.
    • Remove two 3mm Phillips #0 screws under the plastic tab.
  3. Dell XPS 15 9530 WiFi Card Replacement: 3 단계, 이미지 1/1
    • Lift the lower case off.
  4. Dell XPS 15 9530 WiFi Card Replacement, WiFi Card: 4 단계, 이미지 1/1
    • Use a Phillips #0 screwdriver to remove the screw holding the WiFi card down. Be careful not to lose the metal retainer holding the antenna cables down.
    • Without applying too much force, pop out the antenna cables and remove the card.
    • Insert the new card, and reattach the antenna cables. The black cable connects to the main antenna slot (marked with a solid triangle) and the white connects to the auxiliary (marked with an empty triangle).
결론
Matt
회원 가입일: 10/02/19
171 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 17
30일 전: 47
전체 시간: 1,748
