주요 콘텐츠로 건너뛰기
Dell XPS 15 9550 Back/Underside Panel Replacement
필요한 것
  1. Dell XPS 15 9550 Back/Underside Panel Replacement, Back/Underside Panel: 1 단계, 이미지 1/1
    • Turn the laptop upside down.
    • Make sure the laptop is turned off.
    • Use a T5 Torx Screwdriver to remove the ten 3 mm long screws from the perimeter of the back of the laptop.
  2. Dell XPS 15 9550 Back/Underside Panel Replacement: 2 단계, 이미지 1/2 Dell XPS 15 9550 Back/Underside Panel Replacement: 2 단계, 이미지 2/2
    • Open up the information panel door (on the middle of the back side).
    • While holding the door open, use a Phillips #00 Screwdriver to remove the two 10 mm long screws.
  3. Dell XPS 15 9550 Back/Underside Panel Replacement: 3 단계, 이미지 1/3 Dell XPS 15 9550 Back/Underside Panel Replacement: 3 단계, 이미지 2/3 Dell XPS 15 9550 Back/Underside Panel Replacement: 3 단계, 이미지 3/3
    • Carefully lift the 2 corners of the back panel close to the hinge upwards, to release the whole panel.
    • Do not force the panel off. If it does not come off easily, try to use a plastic spudger where it is stuck.
결론
다른 12명이 해당 안내서를 완성하였습니다.
Brandon Schmidt
회원 가입일: 10/04/18
2,090 평판
안내서 3개 작성하였습니다
UW Stout, Team S6-G1, Ogden Fall 2018 UW Stout, Team S6-G1, Ogden Fall 2018 회원
UWSTOUT-OGDEN-F18S6G1
4 회원들
안내서 23개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 21
30일 전: 101
전체 시간: 12,396
