소개
The may need to be replaced if you are running out of storage space, or if you have saved files being corrupted. If the battery works but the computer will not boot up, it may be the SSD. On the Dell XPS 15 9550, it is easily accessible after the back panel is removed.
필요한 것
Turn the laptop upside down.
Use a T5 Torx Screwdriver to remove the ten 3 mm long screws from the perimeter of the back of the laptop.
다른 한 분이 해당 안내서를 완성하였습니다.
