주요 콘텐츠로 건너뛰기
Dell XPS 15 9550 Solid State Drive Replacement
필요한 것
  1. Dell XPS 15 9550 Solid State Drive Replacement, Back/Underside Panel: 1 단계, 이미지 1/1
    • Turn the laptop upside down.
    • Make sure the laptop is turned off.
    • Use a T5 Torx Screwdriver to remove the ten 3 mm long screws from the perimeter of the back of the laptop.
  2. Dell XPS 15 9550 Solid State Drive Replacement: 2 단계, 이미지 1/2 Dell XPS 15 9550 Solid State Drive Replacement: 2 단계, 이미지 2/2
    • Open up the information panel door (on the middle of the back side).
    • While holding the door open, use a Phillips #00 Screwdriver to remove the two 10 mm long screws.
  3. Dell XPS 15 9550 Solid State Drive Replacement: 3 단계, 이미지 1/3 Dell XPS 15 9550 Solid State Drive Replacement: 3 단계, 이미지 2/3 Dell XPS 15 9550 Solid State Drive Replacement: 3 단계, 이미지 3/3
    • Carefully lift the 2 corners of the back panel close to the hinge upwards, to release the whole panel.
    • Do not force the panel off. If it does not come off easily, try to use a plastic spudger where it is stuck.
  4. Dell XPS 15 9550 Solid State Drive Replacement, Solid State Drive: 4 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the SSD screw.
  5. Dell XPS 15 9550 Solid State Drive Replacement: 5 단계, 이미지 1/2 Dell XPS 15 9550 Solid State Drive Replacement: 5 단계, 이미지 2/2
    • Gently remove the SSD.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Zach Jones
회원 가입일: 03/25/22
352 평판
안내서 2개 작성하였습니다
IUPUI, Team 2-4, Harley Spring 2022 IUPUI, Team 2-4, Harley Spring 2022 회원
IUPUI-HARLEY-S22S2G4
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 16
30일 전: 54
전체 시간: 1,999
