소개
If the laptop will not connect to wireless internet, you may need a new wireless card.
필요한 것
Turn the laptop upside down.
Use a T5 Torx Screwdriver to remove the ten 3 mm long screws from the perimeter of the back of the laptop.
With a Philips #00 Screwdriver bit, remove one 4 mm long black screw located by the antenna connections on the wireless card.
Set the screw and metal holder aside.
다른 4명이 해당 안내서를 완성하였습니다.
