주요 콘텐츠로 건너뛰기
Dell XPS 15 9560 Motherboard Replacement
필요한 것
  1. Dell XPS 15 9560 Motherboard Replacement, Back Panel: 1 단계, 이미지 1/1
    • Using a T5 Torx screwdriver, remove ten 4.0 mm screws from the back panel of the laptop.
  2. Dell XPS 15 9560 Motherboard Replacement: 2 단계, 이미지 1/1
    • Using a Phillips #2 screwdriver, remove two 5.0 mm screws underneath the XPS badge door.
  3. Dell XPS 15 9560 Motherboard Replacement: 3 단계, 이미지 1/1
    • Wedge the scribe between the backplate and remove the bottom base cover.
  4. Dell XPS 15 9560 Motherboard Replacement, Battery: 4 단계, 이미지 1/1
    • Using a T5 Torx screwdriver, remove the six 4.0 mm screws.
  5. Dell XPS 15 9560 Motherboard Replacement: 5 단계, 이미지 1/1
    • Unplug the battery cable.
  6. Dell XPS 15 9560 Motherboard Replacement: 6 단계, 이미지 1/1
    • Remove the battery.
  7. Dell XPS 15 9560 Motherboard Replacement, Hard Drive: 7 단계, 이미지 1/1
    • Using a Phillips #0 screwdriver, remove four 4.0 mm screws of the hard drive bracket.
    • Unplug the hard drive cable.
  8. Dell XPS 15 9560 Motherboard Replacement: 8 단계, 이미지 1/1
    • Remove the hard drive bracket. Then, unplug and remove the hard drive.
  9. Dell XPS 15 9560 Motherboard Replacement, Solid State Drive (SSD): 9 단계, 이미지 1/1
    • Using a Phillips #2 screwdriver, remove a single 3.0 mm screw from the SSD bracket.
  10. Dell XPS 15 9560 Motherboard Replacement: 10 단계, 이미지 1/1
    • Using the same Phillips #2 screwdriver, unscrew and remove one 2.0 mm wafer screw from the SSD bracket.
  11. Dell XPS 15 9560 Motherboard Replacement: 11 단계, 이미지 1/1
    • Pull out and separate the SSD bracket and SSD, replacing the old SSD with a new one.
  12. Dell XPS 15 9560 Motherboard Replacement, Wireless Card: 12 단계, 이미지 1/1
    • Using the Phillips #2 screwdriver, remove the single 4.0 mm screw securing the wireless card base to the motherboard.
  13. Dell XPS 15 9560 Motherboard Replacement: 13 단계, 이미지 1/1
    • Disconnect the wireless card cables from the wireless card.
  14. Dell XPS 15 9560 Motherboard Replacement: 14 단계, 이미지 1/1
    • Slide the wireless card out of its slot.
  15. Dell XPS 15 9560 Motherboard Replacement, Fans: 15 단계, 이미지 1/1
    • Using a T5 Torx screwdriver, remove two 4.0 mm screws.
  16. Dell XPS 15 9560 Motherboard Replacement: 16 단계, 이미지 1/1
    • Unplug the fan cable.
  17. Dell XPS 15 9560 Motherboard Replacement: 17 단계, 이미지 1/1
    • Carefully remove the left-side fan.
  18. Dell XPS 15 9560 Motherboard Replacement: 18 단계, 이미지 1/1
  19. Dell XPS 15 9560 Motherboard Replacement: 19 단계, 이미지 1/1
    • Remove the right-side fan.
  20. Dell XPS 15 9560 Motherboard Replacement, RAM: 20 단계, 이미지 1/2 Dell XPS 15 9560 Motherboard Replacement, RAM: 20 단계, 이미지 2/2
    • Pull the metal clips surrounding the RAM stick outward.
    • The RAM will pop out.
    • Remove the RAM stick from the device.
  21. Dell XPS 15 9560 Motherboard Replacement, Motherboard: 21 단계, 이미지 1/1
    • Using a screwdriver, unscrew one 5.0 mm Torx T5 bracket screw.
    • Remove the bracket and unplug and loosen the LCD cable.
  22. Dell XPS 15 9560 Motherboard Replacement: 22 단계, 이미지 1/1
    • Using a T5 Torx screwdriver, remove ten 4.0 mm screws securing the motherboard to the device.
  23. Dell XPS 15 9560 Motherboard Replacement: 23 단계, 이미지 1/1
    • From right to left, unplug the bottom motherboard cables, DC jack cable, speaker cable.
  24. Dell XPS 15 9560 Motherboard Replacement: 24 단계, 이미지 1/1
    • Remove the motherboard.
결론
Jada Houser
회원 가입일: 09/28/21
790 평판
안내서 7개 작성하였습니다
Clemson, Team 4-5, Hunter Fall 2021 Clemson, Team 4-5, Hunter Fall 2021 회원
CLEM-HUNTER-F21S4G5
4 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 21
30일 전: 80
전체 시간: 3,875
