소개
If your Dell XPS 15 9560 boots up with the BIOS menu, produces a beeping pattern upon failure to boot, or has been experiencing hardware and software malfunctioning with all other fixes ruled out, there may be an irreparable issue with the motherboard and it will need to be replaced.
The motherboard is the central hub of the laptop. It distributes power throughout the laptop and allows the laptop’s hardware components to communicate with the processor.
Damage to a laptop’s body or damage by liquids leaking into a laptop can lead to a damaged motherboard. A motherboard may also fail over time as it ages. This is the worst case scenario for many laptops as a damage motherboard means the entire computer is no longer operable.
Before beginning, backup all important files to an external hard drive or a USB. Additionally, make sure the laptop is off and the laptop is disconnected from any power source.
필요한 것
Using a T5 Torx screwdriver, remove ten 4.0 mm screws from the back panel of the laptop.
Using a Phillips #0 screwdriver, remove four 4.0 mm screws of the hard drive bracket.
Unplug the hard drive cable.
Using a Phillips #2 screwdriver, remove a single 3.0 mm screw from the SSD bracket.
Using the Phillips #2 screwdriver, remove the single 4.0 mm screw securing the wireless card base to the motherboard.
Using a screwdriver, unscrew one 5.0 mm Torx T5 bracket screw.
Remove the bracket and unplug and loosen the LCD cable.
