주요 콘텐츠로 건너뛰기
Dell XPS 15 9560 Solid State Drive (SSD) Replacement
필요한 것
  1. Dell XPS 15 9560 Solid State Drive (SSD) Replacement, Back Panel: 1 단계, 이미지 1/1
    • Using a T5 Torx screwdriver, remove ten 4.0 mm screws from the back panel of the laptop.
  2. Dell XPS 15 9560 Solid State Drive (SSD) Replacement: 2 단계, 이미지 1/1
    • Using a Phillips #2 screwdriver, remove two 5.0 mm screws underneath the XPS badge door.
  3. Dell XPS 15 9560 Solid State Drive (SSD) Replacement: 3 단계, 이미지 1/1
    • Wedge the scribe between the backplate and remove the bottom base cover.
  4. Dell XPS 15 9560 Solid State Drive (SSD) Replacement, Solid State Drive (SSD): 4 단계, 이미지 1/1
    • Using a Phillips #2 screwdriver, remove a single 3.0 mm screw from the SSD bracket.
  5. Dell XPS 15 9560 Solid State Drive (SSD) Replacement: 5 단계, 이미지 1/1
    • Using the same Phillips #2 screwdriver, unscrew and remove one 2.0 mm wafer screw from the SSD bracket.
  6. Dell XPS 15 9560 Solid State Drive (SSD) Replacement: 6 단계, 이미지 1/1
    • Pull out and separate the SSD bracket and SSD, replacing the old SSD with a new one.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Frederick Rowell
회원 가입일: 09/28/21
175 평판
안내서 1개 작성함
Clemson, Team 4-5, Hunter Fall 2021 Clemson, Team 4-5, Hunter Fall 2021 회원
CLEM-HUNTER-F21S4G5
4 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 13
30일 전: 73
전체 시간: 2,385
