주요 콘텐츠로 건너뛰기
Dell XPS 15 9570 SSD Replacement
필요한 것
  1. Dell XPS 15 9570 SSD Replacement, Base Cover: 1 단계, 이미지 1/1
    • Make sure your device is powered off and unplugged before starting
    • Flip the device over so the base cover of the computer is facing upwards.
  2. Dell XPS 15 9570 SSD Replacement: 2 단계, 이미지 1/3 Dell XPS 15 9570 SSD Replacement: 2 단계, 이미지 2/3 Dell XPS 15 9570 SSD Replacement: 2 단계, 이미지 3/3
    • Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back.
  3. Dell XPS 15 9570 SSD Replacement: 3 단계, 이미지 1/2 Dell XPS 15 9570 SSD Replacement: 3 단계, 이미지 2/2
    • Flip open the system badge and with a Phillips #00 screwdriver, remove the two 8.5 mm screws.
  4. Dell XPS 15 9570 SSD Replacement: 4 단계, 이미지 1/1
    • Lift the back cover off of the device.
  5. Dell XPS 15 9570 SSD Replacement, SSD: 5 단계, 이미지 1/2 Dell XPS 15 9570 SSD Replacement, SSD: 5 단계, 이미지 2/2
    • Use the Phillips #00 screwdriver to remove the 5.5 mm screw next to the SSD.
  6. Dell XPS 15 9570 SSD Replacement: 6 단계, 이미지 1/2 Dell XPS 15 9570 SSD Replacement: 6 단계, 이미지 2/2
    • Using your hands, hold the SSD and slightly pull to the left.
결론
Baidullah Hazrat
회원 가입일: 02/21/23
85 평판
안내서 1개 작성함
University of Kentucky, Team 1-1, Kaufmann Spring 2023 University of Kentucky, Team 1-1, Kaufmann Spring 2023 회원
UKY-KAUFMANN-S23S1G1
2 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 20
30일 전: 79
전체 시간: 1,395
