주요 콘텐츠로 건너뛰기
Dell XPS 15 9570 Speaker Replacement
필요한 것
  1. Dell XPS 15 9570 Speaker Replacement, Base Cover: 1 단계, 이미지 1/1
    • Make sure your device is powered off and unplugged before starting
    • Flip the device over so the base cover of the computer is facing upwards.
  2. Dell XPS 15 9570 Speaker Replacement: 2 단계, 이미지 1/3 Dell XPS 15 9570 Speaker Replacement: 2 단계, 이미지 2/3 Dell XPS 15 9570 Speaker Replacement: 2 단계, 이미지 3/3
    • Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back.
  3. Dell XPS 15 9570 Speaker Replacement: 3 단계, 이미지 1/2 Dell XPS 15 9570 Speaker Replacement: 3 단계, 이미지 2/2
    • Flip open the system badge and with a Phillips #00 screwdriver, remove the two 8.5 mm screws.
  4. Dell XPS 15 9570 Speaker Replacement: 4 단계, 이미지 1/1
    • Lift the back cover off of the device.
  5. Dell XPS 15 9570 Speaker Replacement, Battery: 5 단계, 이미지 1/1
    • Using the Phillips #00 screwdriver, remove the four 4 mm screws holding the battery in place.
  6. Dell XPS 15 9570 Speaker Replacement: 6 단계, 이미지 1/1
    • Use the iFixit opening tool to disconnect the battery connector from the motherboard.
  7. Dell XPS 15 9570 Speaker Replacement: 7 단계, 이미지 1/1
    • With your hands, pick up and remove the battery from the system.
  8. Dell XPS 15 9570 Speaker Replacement, Speaker: 8 단계, 이미지 1/2 Dell XPS 15 9570 Speaker Replacement, Speaker: 8 단계, 이미지 2/2
    • Using the iFixit opening tool, disconnect the speaker cable by pulling it out gently.
  9. Dell XPS 15 9570 Speaker Replacement: 9 단계, 이미지 1/3 Dell XPS 15 9570 Speaker Replacement: 9 단계, 이미지 2/3 Dell XPS 15 9570 Speaker Replacement: 9 단계, 이미지 3/3
    • Remove the four 2mm screws using the Phillips #00 screwdriver.
    • There are two on the left speaker and two on the right.
    • Follow the images for the right side to complete the left side as well.
  10. Dell XPS 15 9570 Speaker Replacement: 10 단계, 이미지 1/1
    • Remove the speakers from the back of the computer.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Margaret Combs
회원 가입일: 09/08/21
504 평판
안내서 4개 작성하였습니다
University of Alabama, Team 2-4, Bedsole Fall 2021 University of Alabama, Team 2-4, Bedsole Fall 2021 회원
UA-BEDSOLE-F21S2G4
3 회원들
안내서 18개 작성하였습니다
댓글 한 개
Thank you for the tutorial!
Just did the swap with speakers form a DELL XPS 15 from an unknown model (most likely wasn't a 9570). Note that these speakers are common inbetween different XPS 15 models (at least XPS 9550 9560 M5510 9350 5520 5510 and Precision 5510 5520 5530 5540 PK23000RP00 TX47W 0TX47W) ******and can be interchanged.
The ones I just used were salvaged from an out-of-service XPS 15 but the parts can be sourced online easily (ex: https://www.amazon.com/Deal4GO-Speaker-R... )
Cheers
Antalog - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 43
전체 시간: 1,977
