주요 콘텐츠로 건너뛰기
Dell XPS 15 9570 Touchpad Replacement
필요한 것
  1. Dell XPS 15 9570 Touchpad Replacement, Base Cover: 1 단계, 이미지 1/1
    • Make sure your device is powered off and unplugged before starting
    • Flip the device over so the base cover of the computer is facing upwards.
  2. Dell XPS 15 9570 Touchpad Replacement: 2 단계, 이미지 1/3 Dell XPS 15 9570 Touchpad Replacement: 2 단계, 이미지 2/3 Dell XPS 15 9570 Touchpad Replacement: 2 단계, 이미지 3/3
    • Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back.
  3. Dell XPS 15 9570 Touchpad Replacement: 3 단계, 이미지 1/2 Dell XPS 15 9570 Touchpad Replacement: 3 단계, 이미지 2/2
    • Flip open the system badge and with a Phillips #00 screwdriver, remove the two 8.5 mm screws.
  4. Dell XPS 15 9570 Touchpad Replacement: 4 단계, 이미지 1/1
    • Lift the back cover off of the device.
  5. Dell XPS 15 9570 Touchpad Replacement, Battery: 5 단계, 이미지 1/1
    • Using the Phillips #00 screwdriver, remove the four 4 mm screws holding the battery in place.
  6. Dell XPS 15 9570 Touchpad Replacement: 6 단계, 이미지 1/1
    • Use the iFixit opening tool to disconnect the battery connector from the motherboard.
  7. Dell XPS 15 9570 Touchpad Replacement: 7 단계, 이미지 1/1
    • With your hands, pick up and remove the battery from the system.
  8. Dell XPS 15 9570 Touchpad Replacement, Heat Sink: 8 단계, 이미지 1/2 Dell XPS 15 9570 Touchpad Replacement, Heat Sink: 8 단계, 이미지 2/2
    • Use the Phillips #00 to remove the three (without graphics card) or four (with graphics card) 3 mm screws that connect the heat sink to the system board.
  9. Dell XPS 15 9570 Touchpad Replacement: 9 단계, 이미지 1/1
    • Lift the heat sink from the device. The thermal paste may have dried and make this handling more complicated, be careful.
  10. Dell XPS 15 9570 Touchpad Replacement, Fan: 10 단계, 이미지 1/2 Dell XPS 15 9570 Touchpad Replacement, Fan: 10 단계, 이미지 2/2
    • Use the Phillips #00 screwdriver to remove the two 4 mm screws securing the grey display cable bracket.
  11. Dell XPS 15 9570 Touchpad Replacement: 11 단계, 이미지 1/1
    • Using the Phillips #00 screwdriver, remove the 4 mm screw at the back right corner of the fan.
  12. Dell XPS 15 9570 Touchpad Replacement: 12 단계, 이미지 1/2 Dell XPS 15 9570 Touchpad Replacement: 12 단계, 이미지 2/2
    • Disconnect the fan cable on the left of the fan and on the right side from the RAM, using the opening tool.
  13. Dell XPS 15 9570 Touchpad Replacement: 13 단계, 이미지 1/1
    • Lift the right fan off of the device.
    • Repeat steps 8-11 to remove the left fan from the system board.
    • The left fan is fixed with two 4 mm screws. Make sure you have removed them if the fan does not come off easily.
  14. Dell XPS 15 9570 Touchpad Replacement, RAM: 14 단계, 이미지 1/2 Dell XPS 15 9570 Touchpad Replacement, RAM: 14 단계, 이미지 2/2
    • Use your fingers to pinch down the metal tabs holding the RAM in place. Do this for each tab.
  15. Dell XPS 15 9570 Touchpad Replacement: 15 단계, 이미지 1/1
    • Use your hands to carefully lift the RAM up and away from the tabs to safely take it out.
  16. Dell XPS 15 9570 Touchpad Replacement, SSD: 16 단계, 이미지 1/2 Dell XPS 15 9570 Touchpad Replacement, SSD: 16 단계, 이미지 2/2
    • Use the Phillips #00 screwdriver to remove the 5.5 mm screw next to the SSD.
  17. Dell XPS 15 9570 Touchpad Replacement: 17 단계, 이미지 1/2 Dell XPS 15 9570 Touchpad Replacement: 17 단계, 이미지 2/2
    • Using your hands, hold the SSD and slightly pull to the left.
  18. Dell XPS 15 9570 Touchpad Replacement, Wireless Card: 18 단계, 이미지 1/2 Dell XPS 15 9570 Touchpad Replacement, Wireless Card: 18 단계, 이미지 2/2
    • Using a Phillips #00 screwdriver, loosen the captive screw holding the wireless card bracket in place.
  19. Dell XPS 15 9570 Touchpad Replacement: 19 단계, 이미지 1/1
    • Lift the wireless card bracket off of the wireless card.
  20. Dell XPS 15 9570 Touchpad Replacement: 20 단계, 이미지 1/2 Dell XPS 15 9570 Touchpad Replacement: 20 단계, 이미지 2/2
    • Using a spudger, disconnect the coaxial antenna cables from the Wi-Fi card by popping them gently off.
  21. Dell XPS 15 9570 Touchpad Replacement: 21 단계, 이미지 1/1
    • Carefully remove the wireless card.
  22. Dell XPS 15 9570 Touchpad Replacement, Speaker: 22 단계, 이미지 1/2 Dell XPS 15 9570 Touchpad Replacement, Speaker: 22 단계, 이미지 2/2
    • Using the iFixit opening tool, disconnect the speaker cable by pulling it out gently.
  23. Dell XPS 15 9570 Touchpad Replacement: 23 단계, 이미지 1/3 Dell XPS 15 9570 Touchpad Replacement: 23 단계, 이미지 2/3 Dell XPS 15 9570 Touchpad Replacement: 23 단계, 이미지 3/3
    • Remove the four 2mm screws using the Phillips #00 screwdriver.
    • There are two on the left speaker and two on the right.
    • Follow the images for the right side to complete the left side as well.
  24. Dell XPS 15 9570 Touchpad Replacement: 24 단계, 이미지 1/1
    • Remove the speakers from the back of the computer.
  25. Dell XPS 15 9570 Touchpad Replacement, Touchpad: 25 단계, 이미지 1/2 Dell XPS 15 9570 Touchpad Replacement, Touchpad: 25 단계, 이미지 2/2
    • Disconnect the two motherboard cables using the opening tool.
  26. Dell XPS 15 9570 Touchpad Replacement: 26 단계, 이미지 1/3 Dell XPS 15 9570 Touchpad Replacement: 26 단계, 이미지 2/3 Dell XPS 15 9570 Touchpad Replacement: 26 단계, 이미지 3/3
    • Using a Phillips #0 screwdriver, remove the four 4mm screws securing the hard drive cover.
  27. Dell XPS 15 9570 Touchpad Replacement: 27 단계, 이미지 1/3 Dell XPS 15 9570 Touchpad Replacement: 27 단계, 이미지 2/3 Dell XPS 15 9570 Touchpad Replacement: 27 단계, 이미지 3/3
    • Disconnect the two motherboard cables located on the right of the motherboard using the opening tool.
  28. Dell XPS 15 9570 Touchpad Replacement: 28 단계, 이미지 1/2 Dell XPS 15 9570 Touchpad Replacement: 28 단계, 이미지 2/2
    • Using a Phillips #0 screwdriver, unscrew the 4 remaining 4mm screws holding the motherboard in place.
    • Remove the motherboard.
  29. Dell XPS 15 9570 Touchpad Replacement: 29 단계, 이미지 1/3 Dell XPS 15 9570 Touchpad Replacement: 29 단계, 이미지 2/3 Dell XPS 15 9570 Touchpad Replacement: 29 단계, 이미지 3/3
    • Using a Phillips #0 screwdriver, unscrew the two 2.4mm screws holding the touchpad in place.
    • Remove the touchpad.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Sophie
회원 가입일: 11/09/23
289 평판
안내서 2개 작성하였습니다
IUPUI, Team 3-1, Harley Fall 2023 IUPUI, Team 3-1, Harley Fall 2023 회원
IUPUI-HARLEY-F23S3G1
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 11
30일 전: 43
전체 시간: 359
