소개
You can use this guide to learn the steps to remove the touchpad of your Dell XPS 15 9570. The keypad allows for user input and interaction with the device. A faulty keypad makes operating the device difficult to impossible.
Prior to starting this guide, be sure the laptop is powered off and it is unplugged from the charging cord.
필요한 것
Using the Phillips #00 screwdriver, remove the four 4 mm screws holding the battery in place.
Use the Phillips #00 to remove the three (without graphics card) or four (with graphics card) 3 mm screws that connect the heat sink to the system board.
Using a Phillips #00 screwdriver, loosen the captive screw holding the wireless card bracket in place.
Using the iFixit opening tool, disconnect the speaker cable by pulling it out gently.
다른 한 분이 해당 안내서를 완성하였습니다.
