주요 콘텐츠로 건너뛰기
Dell XPS 15 9570 Wireless Card Replacement
필요한 것
  1. Dell XPS 15 9570 Wireless Card Replacement, Base Cover: 1 단계, 이미지 1/1
    • Make sure your device is powered off and unplugged before starting
    • Flip the device over so the base cover of the computer is facing upwards.
  2. Dell XPS 15 9570 Wireless Card Replacement: 2 단계, 이미지 1/3 Dell XPS 15 9570 Wireless Card Replacement: 2 단계, 이미지 2/3 Dell XPS 15 9570 Wireless Card Replacement: 2 단계, 이미지 3/3
    • Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back.
  3. Dell XPS 15 9570 Wireless Card Replacement: 3 단계, 이미지 1/2 Dell XPS 15 9570 Wireless Card Replacement: 3 단계, 이미지 2/2
    • Flip open the system badge and with a Phillips #00 screwdriver, remove the two 8.5 mm screws.
  4. Dell XPS 15 9570 Wireless Card Replacement: 4 단계, 이미지 1/1
    • Lift the back cover off of the device.
  5. Dell XPS 15 9570 Wireless Card Replacement, Wireless Card: 5 단계, 이미지 1/2 Dell XPS 15 9570 Wireless Card Replacement, Wireless Card: 5 단계, 이미지 2/2
    • Using a Phillips #00 screwdriver, loosen the captive screw holding the wireless card bracket in place.
  6. Dell XPS 15 9570 Wireless Card Replacement: 6 단계, 이미지 1/1
    • Lift the wireless card bracket off of the wireless card.
  7. Dell XPS 15 9570 Wireless Card Replacement: 7 단계, 이미지 1/2 Dell XPS 15 9570 Wireless Card Replacement: 7 단계, 이미지 2/2
    • Using a spudger, disconnect the coaxial antenna cables from the Wi-Fi card by popping them gently off.
  8. Dell XPS 15 9570 Wireless Card Replacement: 8 단계, 이미지 1/1
    • Carefully remove the wireless card.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Margaret Combs
회원 가입일: 09/08/21
504 평판
안내서 4개 작성하였습니다
University of Alabama, Team 2-4, Bedsole Fall 2021 University of Alabama, Team 2-4, Bedsole Fall 2021 회원
UA-BEDSOLE-F21S2G4
3 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 48
전체 시간: 2,320
