주요 콘텐츠로 건너뛰기
Dell XPS 15 Motherboard Replacement
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. Dell XPS 15 Motherboard Replacement, Back Cover: 1 단계, 이미지 1/2 Dell XPS 15 Motherboard Replacement, Back Cover: 1 단계, 이미지 2/2
    • Remove the eight 4 mm T5 Torx screws from the bottom cover.
  2. Dell XPS 15 Motherboard Replacement: 2 단계, 이미지 1/2 Dell XPS 15 Motherboard Replacement: 2 단계, 이미지 2/2
    • Use a plastic opening tool to pry open the 'XPS' flap in the middle.
  3. Dell XPS 15 Motherboard Replacement: 3 단계, 이미지 1/1
    • Remove the single Phillips screw hidden beneath the flap.
  4. Dell XPS 15 Motherboard Replacement: 4 단계, 이미지 1/1
    • Use opening picks or a plastic pry tool to pry open the case clips, beginning from the back edge.
  5. Dell XPS 15 Motherboard Replacement: 5 단계, 이미지 1/1
    • Remove the bottom cover.
  6. Dell XPS 15 Motherboard Replacement, Battery Disconnection: 6 단계, 이미지 1/2 Dell XPS 15 Motherboard Replacement, Battery Disconnection: 6 단계, 이미지 2/2
    • Pull the battery cable connector towards the battery to disconnect it from its socket.
    • If the connector is stubborn, push a little at one side, then the other, to "walk" it out of its socket.
    • If you have trouble walking the connector out of the socket, use the point of a spudger to gently push on the connector indent to slide the connector out.
    • Do not pull up.
    • Open the display and press the power button for five seconds to drain any remaining charge from the system.
  7. Dell XPS 15 Motherboard Replacement, Fan: 7 단계, 이미지 1/3 Dell XPS 15 Motherboard Replacement, Fan: 7 단계, 이미지 2/3 Dell XPS 15 Motherboard Replacement, Fan: 7 단계, 이미지 3/3
    • Use tweezers to remove the little white connector by pulling it out and away from its socket.
  8. Dell XPS 15 Motherboard Replacement: 8 단계, 이미지 1/2 Dell XPS 15 Motherboard Replacement: 8 단계, 이미지 2/2
    • Remove the black standard flat connector by lifting the tab up with your hand.
  9. Dell XPS 15 Motherboard Replacement: 9 단계, 이미지 1/2 Dell XPS 15 Motherboard Replacement: 9 단계, 이미지 2/2
    • Remove the 4 mm Phillips #0 screw that connects the fan to the motherboard.
    • Remove the 4 mm Phillips #0 screw that connects the fan to the base of the computer.
  10. Dell XPS 15 Motherboard Replacement: 10 단계, 이미지 1/2 Dell XPS 15 Motherboard Replacement: 10 단계, 이미지 2/2
    • Use your right hand to lift up the larger section of the motherboard, closest to the fan.
    • Use your left hand to pull the fan at a 30-degree angle out from underneath the motherboard.
  11. Dell XPS 15 Motherboard Replacement, Battery: 11 단계, 이미지 1/2 Dell XPS 15 Motherboard Replacement, Battery: 11 단계, 이미지 2/2
    • Remove the four 3 mm Phillips #0 screws located on each corner of the battery.
  12. Dell XPS 15 Motherboard Replacement: 12 단계, 이미지 1/2 Dell XPS 15 Motherboard Replacement: 12 단계, 이미지 2/2
    • Do not pull up.
  13. Dell XPS 15 Motherboard Replacement: 13 단계, 이미지 1/1
    • Peel up any tape securing the speaker cables to the battery.
    • You do not need to remove the speakers, only the tape, allowing the battery to be removed out under the speaker cables.
  14. Dell XPS 15 Motherboard Replacement: 14 단계, 이미지 1/1
    • Remove the battery.
  15. Dell XPS 15 Motherboard Replacement, Motherboard: 15 단계, 이미지 1/2 Dell XPS 15 Motherboard Replacement, Motherboard: 15 단계, 이미지 2/2
    • Remove the eight 4 mm Phillips #0 screws from the motherboard.
  16. Dell XPS 15 Motherboard Replacement: 16 단계, 이미지 1/3 Dell XPS 15 Motherboard Replacement: 16 단계, 이미지 2/3 Dell XPS 15 Motherboard Replacement: 16 단계, 이미지 3/3
    • Locate the red and black cable connector at the bottom right of the motherboard.
    • Use tweezers to slowly detach the cable connector from its socket by pulling it to the right and up.
  17. Dell XPS 15 Motherboard Replacement: 17 단계, 이미지 1/3 Dell XPS 15 Motherboard Replacement: 17 단계, 이미지 2/3 Dell XPS 15 Motherboard Replacement: 17 단계, 이미지 3/3
    • Use tweezers to flip open the Zero Insertion Force (ZIF) connector.
    • Use tweezers to detach the ribbon cable from the ZIF by pulling it towards yourself.
  18. Dell XPS 15 Motherboard Replacement: 18 단계, 이미지 1/3 Dell XPS 15 Motherboard Replacement: 18 단계, 이미지 2/3 Dell XPS 15 Motherboard Replacement: 18 단계, 이미지 3/3
    • Use tweezers to flip open the white ZIF connector.
    • Use tweezers to detach the ribbon connector from the ZIF by pulling it towards yourself.
  19. Dell XPS 15 Motherboard Replacement: 19 단계, 이미지 1/3 Dell XPS 15 Motherboard Replacement: 19 단계, 이미지 2/3 Dell XPS 15 Motherboard Replacement: 19 단계, 이미지 3/3
    • Use tweezers to flip open the ZIF connector.
    • Use tweezers to detach the orange ribbon connector from the ZIF by pulling it towards yourself.
  20. Dell XPS 15 Motherboard Replacement: 20 단계, 이미지 1/2 Dell XPS 15 Motherboard Replacement: 20 단계, 이미지 2/2
    • Use tweezers to detach the black cable connector out of its socket by pulling it to the right.
  21. Dell XPS 15 Motherboard Replacement: 21 단계, 이미지 1/3 Dell XPS 15 Motherboard Replacement: 21 단계, 이미지 2/3 Dell XPS 15 Motherboard Replacement: 21 단계, 이미지 3/3
    • Use tweezers to gently detach the black and white cable connector out of its socket by pulling it to the right.
  22. Dell XPS 15 Motherboard Replacement: 22 단계, 이미지 1/2 Dell XPS 15 Motherboard Replacement: 22 단계, 이미지 2/2
    • Locate the connector at the top right of the motherboard.
    • Use tweezers to detach the cable connector from its socket by pulling it to the right.
  23. Dell XPS 15 Motherboard Replacement: 23 단계, 이미지 1/3 Dell XPS 15 Motherboard Replacement: 23 단계, 이미지 2/3 Dell XPS 15 Motherboard Replacement: 23 단계, 이미지 3/3
    • Locate the last black cable connector.
    • Use tweezers to detach the black cable connector from its socket by pulling it to the right.
  24. Dell XPS 15 Motherboard Replacement: 24 단계, 이미지 1/1
    • Use your hands to lift up the motherboard.
결론
다른 12명이 해당 안내서를 완성하였습니다.
Evan Shui
회원 가입일: 04/26/17
320 평판
안내서 1개 작성함
Cal Poly, Team S21-G6, Livingston Spring 2017 Cal Poly, Team S21-G6, Livingston Spring 2017 회원
CPSU-LIVINGSTON-S17S21G6
5 회원들
안내서 30개 작성하였습니다
댓글 2개
where is camera cable
phong thanh - 답글
Wow man that is awesome job. Where can you get a newer motheboard for the same laptop?
R E - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 31
30일 전: 156
전체 시간: 23,758
