소개
If your current SSD card in your Dell XPS17 9710 no longer has enough storage space or is failing, you may need to replace it.
Before replacing the SSD, make sure to back up any storage currently on the card to another hard drive.
Before beginning make sure to power off your device completely.
필요한 것
Remove eight 5 mm screws from the back panel using a T5 Torx screwdriver.
Use the opening tool to loosen the panel on all sides and then lift it from the device.
거의 끝나갑니다!
결승점
