주요 콘텐츠로 건너뛰기
Dell XPS 17 L702X Hard Drive Replacement
필요한 것
  1. Dell XPS 17 L702X Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Flip over the laptop so that the bottom battery compartment faces upwards.
  2. Dell XPS 17 L702X Hard Drive Replacement: 2 단계, 이미지 1/2 Dell XPS 17 L702X Hard Drive Replacement: 2 단계, 이미지 2/2
    • Slide the tab below the battery to the left and hold the tab in place.
  3. Dell XPS 17 L702X Hard Drive Replacement: 3 단계, 이미지 1/2 Dell XPS 17 L702X Hard Drive Replacement: 3 단계, 이미지 2/2
    • While holding the tab, lift the battery out of its compartment.
    • Release the tab after removing the battery.
  4. Dell XPS 17 L702X Hard Drive Replacement, Hard Drive: 4 단계, 이미지 1/1
    • Loosen the module cover screw with a Phillips screwdriver.
    • The screw is attached to the cover; do not force it out.
  5. Dell XPS 17 L702X Hard Drive Replacement: 5 단계, 이미지 1/3 Dell XPS 17 L702X Hard Drive Replacement: 5 단계, 이미지 2/3 Dell XPS 17 L702X Hard Drive Replacement: 5 단계, 이미지 3/3
    • Lift the module cover by inserting a plastic opening tool into the crevice near the screw and lift upwards.
  6. Dell XPS 17 L702X Hard Drive Replacement: 6 단계, 이미지 1/2 Dell XPS 17 L702X Hard Drive Replacement: 6 단계, 이미지 2/2
    • Remove the four 4mm Phillips screws fastening the first hard drive.
  7. Dell XPS 17 L702X Hard Drive Replacement: 7 단계, 이미지 1/3 Dell XPS 17 L702X Hard Drive Replacement: 7 단계, 이미지 2/3 Dell XPS 17 L702X Hard Drive Replacement: 7 단계, 이미지 3/3
    • Slide the hard drive with your hand towards the hole where the back panel assembly screw was located (in step 5) to disconnect it.
    • Lift the hard drive up to remove it from the case.
  8. Dell XPS 17 L702X Hard Drive Replacement: 8 단계, 이미지 1/1
    • Remove the four 4mm Phillips screws on the second hard drive.
  9. Dell XPS 17 L702X Hard Drive Replacement: 9 단계, 이미지 1/2 Dell XPS 17 L702X Hard Drive Replacement: 9 단계, 이미지 2/2
    • Slide the hard drive towards the edge nearest you to disconnect it.
  10. Dell XPS 17 L702X Hard Drive Replacement: 10 단계, 이미지 1/3 Dell XPS 17 L702X Hard Drive Replacement: 10 단계, 이미지 2/3 Dell XPS 17 L702X Hard Drive Replacement: 10 단계, 이미지 3/3
    • Using the tab that says "THIS SIDE UP," pull away from the laptop to remove the hard drive.
  11. Dell XPS 17 L702X Hard Drive Replacement: 11 단계, 이미지 1/2 Dell XPS 17 L702X Hard Drive Replacement: 11 단계, 이미지 2/2
    • Repeat this step for each hard drive.
    • Unscrew the two 4mm screws from each side of the hard drive casing with a Phillips screwdriver.
  12. Dell XPS 17 L702X Hard Drive Replacement: 12 단계, 이미지 1/1
    • Remove the hard drive casing.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Shin Sul
회원 가입일: 10/02/15
544 평판
안내서 3개 작성하였습니다
CSU Fullerton, Team 2-6, Bruce Fall 2015 CSU Fullerton, Team 2-6, Bruce Fall 2015 회원
CSUF-BRUCE-F15S2G6
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 27
전체 시간: 4,332
