주요 콘텐츠로 건너뛰기
Dell XPS 18 Battery Replacement
필요한 것
  1. Dell XPS 18 Battery Replacement, Back Cover: 1 단계, 이미지 1/1
    • Turn the device on its screen.
    • Remove the ten 4mm screws using a T8 Torx screwdriver.
  2. Dell XPS 18 Battery Replacement: 2 단계, 이미지 1/1
    • Gently flip out support feet located near the bottom of device.
  3. Dell XPS 18 Battery Replacement: 3 단계, 이미지 1/1
    • Gently lift the back cover off the device. The back cover should come off easily.
  4. Dell XPS 18 Battery Replacement, Internal Cover: 4 단계, 이미지 1/1
    • Use the opening tool's angled edge to lift the clasps securing the screen and motherboard cables.
  5. Dell XPS 18 Battery Replacement: 5 단계, 이미지 1/2 Dell XPS 18 Battery Replacement: 5 단계, 이미지 2/2
    • Disconnect the screen and copper colored motherboard cables and tuck them under the device to prevent future hassle.
  6. Dell XPS 18 Battery Replacement: 6 단계, 이미지 1/2 Dell XPS 18 Battery Replacement: 6 단계, 이미지 2/2
    • Remove the two black 3mm screws from the internal cover with a Phillips 00 screwdriver.
    • Remove the internal cover.
  7. Dell XPS 18 Battery Replacement, Touch Control Board: 7 단계, 이미지 1/2 Dell XPS 18 Battery Replacement, Touch Control Board: 7 단계, 이미지 2/2
    • Disconnect the black camera cable and pull it back to prevent future hassle.
  8. Dell XPS 18 Battery Replacement: 8 단계, 이미지 1/2 Dell XPS 18 Battery Replacement: 8 단계, 이미지 2/2
    • Use the angled edge of the plastic opening tool to lift the clasp securing the touch control board cable.
    • Disconnect the silver and blue touch control board cable.
  9. Dell XPS 18 Battery Replacement: 9 단계, 이미지 1/2 Dell XPS 18 Battery Replacement: 9 단계, 이미지 2/2
    • Remove the two silver 3mm screws holding the touch control board in place with a Phillips 00 screwdriver.
    • Remove the touch control board.
  10. Dell XPS 18 Battery Replacement, Wireless WLAN Card Wires: 10 단계, 이미지 1/1
    • Use the plastic opening tool's angled edge to remove the black and white wires connected to the wireless WLAN card.
  11. Dell XPS 18 Battery Replacement: 11 단계, 이미지 1/2 Dell XPS 18 Battery Replacement: 11 단계, 이미지 2/2
    • Pull back the cables.
  12. Dell XPS 18 Battery Replacement, Battery: 12 단계, 이미지 1/1
    • Use the plastic opening tool's angled edge to pry the black battery cable loose.
  13. Dell XPS 18 Battery Replacement: 13 단계, 이미지 1/1
    • Use the plastic opening tool's angled edge to remove the red and black CMOS battery cable.
  14. Dell XPS 18 Battery Replacement: 14 단계, 이미지 1/2 Dell XPS 18 Battery Replacement: 14 단계, 이미지 2/2
    • Use the plastic opening tool's angled edge to lift the clasp securing the silver circuit board cable.
    • Pull back the circuit board cable to prevent future hassle.
  15. Dell XPS 18 Battery Replacement: 15 단계, 이미지 1/1
    • Use the opening tool's angled edge to remove the CMOS battery.
    • The CMOS battery is adhered with strong adhesive; you may need to use extra force when removing.
  16. Dell XPS 18 Battery Replacement: 16 단계, 이미지 1/1
    • Remove the eleven black 4mm screws holding the battery in place with a Phillips 00 screwdriver.
  17. Dell XPS 18 Battery Replacement: 17 단계, 이미지 1/1
    • Remove the battery.
결론
다른 13명이 해당 안내서를 완성하였습니다.
Austin Weir
회원 가입일: 01/31/15
1,287 평판
안내서 8개 작성하였습니다
Cal Poly, Team 6-29, Amido Winter 2015 Cal Poly, Team 6-29, Amido Winter 2015 회원
CPSU-AMIDO-W15S6G29
4 회원들
안내서 16개 작성하였습니다
댓글 9개
needs the help to repair the Dell XPS18
anrew waleta - 답글
This is an excellent doc! Pictures are really clear and accurate, steps are concise and best of all they are correct. I was able to solve my issue the first go round with these instructions. Kudos to the author and thanks a million for the assistance!
stacysaw - 답글
It all worked good. Thanks.
Kenneth Macdonald - 답글
Excellent!
What is the battery type and where to buy, thanks
Mohammad - 답글
My unit is missing the right foot stand. Is there anywhere else I can find the model number. Need to purchase a new power supply?
Also might need to replace the touchscreen its cracked. Have to power her up first to find out. Do you have a video for touchscreen replacement?
Frank Schofield - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 41
전체 시간: 15,902
