주요 콘텐츠로 건너뛰기
Dell XPS 18 Left and Right Speakers Replacement
필요한 것
  1. Dell XPS 18 Left and Right Speakers Replacement, Back Cover: 1 단계, 이미지 1/1
    • Turn the device on its screen.
    • Remove the ten 4mm screws using a T8 Torx screwdriver.
  2. Dell XPS 18 Left and Right Speakers Replacement: 2 단계, 이미지 1/1
    • Gently flip out support feet located near the bottom of device.
  3. Dell XPS 18 Left and Right Speakers Replacement: 3 단계, 이미지 1/1
    • Gently lift the back cover off the device. The back cover should come off easily.
  4. Dell XPS 18 Left and Right Speakers Replacement, Left and Right Speakers: 4 단계, 이미지 1/2 Dell XPS 18 Left and Right Speakers Replacement, Left and Right Speakers: 4 단계, 이미지 2/2
    • Use the plastic opening tool's angled edge to lift the clasp securing the copper colored volume control cable.
    • Disconnect the volume control cable and pull it back.
  5. Dell XPS 18 Left and Right Speakers Replacement: 5 단계, 이미지 1/1
    • Firmly pull the blue speaker cable loose.
  6. Dell XPS 18 Left and Right Speakers Replacement: 6 단계, 이미지 1/1
    • Remove the two black 4mm screws with a Phillips 00 screwdriver.
  7. Dell XPS 18 Left and Right Speakers Replacement: 7 단계, 이미지 1/1
    • Carefully remove the speaker.
    • To remove the right speaker, follow these same steps.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Austin Weir
회원 가입일: 01/31/15
1,287 평판
안내서 8개 작성하였습니다
Cal Poly, Team 6-29, Amido Winter 2015 Cal Poly, Team 6-29, Amido Winter 2015 회원
CPSU-AMIDO-W15S6G29
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 13
전체 시간: 1,229
