주요 콘텐츠로 건너뛰기
Dell XPS 18 Support Feet Replacement
필요한 것
  1. Dell XPS 18 Support Feet Replacement, Back Cover: 1 단계, 이미지 1/1
    • Turn the device on its screen.
    • Remove the ten 4mm screws using a T8 Torx screwdriver.
  2. Dell XPS 18 Support Feet Replacement: 2 단계, 이미지 1/1
    • Gently flip out support feet located near the bottom of device.
  3. Dell XPS 18 Support Feet Replacement: 3 단계, 이미지 1/1
    • Gently lift the back cover off the device. The back cover should come off easily.
  4. Dell XPS 18 Support Feet Replacement, Support Feet: 4 단계, 이미지 1/1
    • Fold down the support foot.
  5. Dell XPS 18 Support Feet Replacement: 5 단계, 이미지 1/1
    • Remove the two silver 3mm screws with a Phillips 00 screwdriver.
  6. Dell XPS 18 Support Feet Replacement: 6 단계, 이미지 1/1
    • Remove the silver metal piece holding the support feet down.
  7. Dell XPS 18 Support Feet Replacement: 7 단계, 이미지 1/1
    • Remove the support foot.
    • Follow these same steps for the remaining support foot.
결론
Austin Weir
회원 가입일: 01/31/15
1,287 평판
안내서 8개 작성하였습니다
Cal Poly, Team 6-29, Amido Winter 2015 Cal Poly, Team 6-29, Amido Winter 2015 회원
CPSU-AMIDO-W15S6G29
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 12
전체 시간: 2,003
