주요 콘텐츠로 건너뛰기
Dell XPS 18 Wireless WLAN Card WIRES
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. Dell XPS 18 Wireless WLAN Card WIRES, Back Cover: 1 단계, 이미지 1/1
    • Turn the device on its screen.
    • Remove the ten 4mm screws using a T8 Torx screwdriver.
  2. Dell XPS 18 Wireless WLAN Card WIRES: 2 단계, 이미지 1/1
    • Gently flip out support feet located near the bottom of device.
  3. Dell XPS 18 Wireless WLAN Card WIRES: 3 단계, 이미지 1/1
    • Gently lift the back cover off the device. The back cover should come off easily.
  4. Dell XPS 18 Wireless WLAN Card WIRES, Internal Cover: 4 단계, 이미지 1/1
    • Use the opening tool's angled edge to lift the clasps securing the screen and motherboard cables.
  5. Dell XPS 18 Wireless WLAN Card WIRES: 5 단계, 이미지 1/2 Dell XPS 18 Wireless WLAN Card WIRES: 5 단계, 이미지 2/2
    • Disconnect the screen and copper colored motherboard cables and tuck them under the device to prevent future hassle.
  6. Dell XPS 18 Wireless WLAN Card WIRES: 6 단계, 이미지 1/2 Dell XPS 18 Wireless WLAN Card WIRES: 6 단계, 이미지 2/2
    • Remove the two black 3mm screws from the internal cover with a Phillips 00 screwdriver.
    • Remove the internal cover.
  7. Dell XPS 18 Wireless WLAN Card WIRES, Touch Control Board: 7 단계, 이미지 1/2 Dell XPS 18 Wireless WLAN Card WIRES, Touch Control Board: 7 단계, 이미지 2/2
    • Disconnect the black camera cable and pull it back to prevent future hassle.
  8. Dell XPS 18 Wireless WLAN Card WIRES: 8 단계, 이미지 1/2 Dell XPS 18 Wireless WLAN Card WIRES: 8 단계, 이미지 2/2
    • Use the angled edge of the plastic opening tool to lift the clasp securing the touch control board cable.
    • Disconnect the silver and blue touch control board cable.
  9. Dell XPS 18 Wireless WLAN Card WIRES: 9 단계, 이미지 1/2 Dell XPS 18 Wireless WLAN Card WIRES: 9 단계, 이미지 2/2
    • Remove the two silver 3mm screws holding the touch control board in place with a Phillips 00 screwdriver.
    • Remove the touch control board.
  10. Dell XPS 18 Wireless WLAN Card WIRES, Wireless WLAN Card Wires: 10 단계, 이미지 1/1
    • Use the plastic opening tool's angled edge to remove the black and white wires connected to the wireless WLAN card.
  11. Dell XPS 18 Wireless WLAN Card WIRES: 11 단계, 이미지 1/2 Dell XPS 18 Wireless WLAN Card WIRES: 11 단계, 이미지 2/2
    • Pull back the cables.
결론
Austin Weir
회원 가입일: 01/31/15
1,287 평판
안내서 8개 작성하였습니다
Cal Poly, Team 6-29, Amido Winter 2015 Cal Poly, Team 6-29, Amido Winter 2015 회원
CPSU-AMIDO-W15S6G29
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 7
전체 시간: 56
