주요 콘텐츠로 건너뛰기
Dell XPS 720 H2C Card Fan Replacement
  1. Dell XPS 720 H2C Card Fan Replacement, Removing Dell XPS 720 H2C Cover Panel: 1 단계, 이미지 2개 중 1개 Dell XPS 720 H2C Card Fan Replacement, Removing Dell XPS 720 H2C Cover Panel: 1 단계, 이미지 2개 중 2개
    • Remove the cover panel on the side of the computer by pulling out the latch on the back panel and pulling the panel downwards towards the ground.
  2. Dell XPS 720 H2C Card Fan Replacement, Card Fan: 2 단계, 이미지 2개 중 1개 Dell XPS 720 H2C Card Fan Replacement, Card Fan: 2 단계, 이미지 2개 중 2개
    • The card fan is located at the bottom left corner of the computer.
    • Remove the cable connecting the fan to the motherboard.
    • You will have to push a tiny lever on top of the connector and pull the cable to the left at the same time to remove the cable from the motherboard.
  3. Dell XPS 720 H2C Card Fan Replacement: 3 단계, 이미지 2개 중 1개 Dell XPS 720 H2C Card Fan Replacement: 3 단계, 이미지 2개 중 2개
    • Disconnect the fan from the cage housing by pressing down on the release triggers and pushing them to the right.
  4. Dell XPS 720 H2C Card Fan Replacement: 4 단계, 이미지 2개 중 1개 Dell XPS 720 H2C Card Fan Replacement: 4 단계, 이미지 2개 중 2개
    • Slide each corner of the fan cage off of the rubber grommets attached to the fan.
    • The rubber grommets may be difficult to remove. You have to squeeze the base of the grommet and pull the cage apart at the same time. The grommets should be pulled apart one at a time.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
G B
회원 가입일: 04/17/13
67 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 8
전체 시간: 2,001
