주요 콘텐츠로 건너뛰기
Dell XPS M1210 RAM Replacement
필요한 것
  1. Dell XPS M1210 RAM Replacement, RAM: 1 단계, 이미지 1/3 Dell XPS M1210 RAM Replacement, RAM: 1 단계, 이미지 2/3 Dell XPS M1210 RAM Replacement, RAM: 1 단계, 이미지 3/3
    • Steps for Bottom-Side Memory Slot
    • Turn off the computer, unplug the power adapter. Remove the battery, after sliding the battery latch, until you hear a click.
    • Remove 1 star screw, so you can remove memory cover. Using your fingertips, spread apart the clips, which secure the memory module in place.
  2. Dell XPS M1210 RAM Replacement: 2 단계, 이미지 1/3 Dell XPS M1210 RAM Replacement: 2 단계, 이미지 2/3 Dell XPS M1210 RAM Replacement: 2 단계, 이미지 3/3
    • Once unsecured, the memory module will pop up, so you can remove it at a 45-degree angle.
    • When installing the new memory module, you will notice it can only be inserted in one direction, due to the memory module indents.
    • Secure the module with the clips, click it into place, and reinstall the memory module cover in reverse order of the above instructions.
  3. Dell XPS M1210 RAM Replacement: 3 단계, 이미지 1/2 Dell XPS M1210 RAM Replacement: 3 단계, 이미지 2/2
    • Steps for Top-Side Memory Slot
    • Remove the battery, after sliding the battery latch, until you hear a click.
  4. Dell XPS M1210 RAM Replacement: 4 단계, 이미지 1/3 Dell XPS M1210 RAM Replacement: 4 단계, 이미지 2/3 Dell XPS M1210 RAM Replacement: 4 단계, 이미지 3/3
    • With the laptop screen tilted 180-degrees, you can begin removing the rear hinge panel. The cover is not attached to any wires and covers the screws which secure the keyboard in place.
    • With the flat-head screwdriver or a thin object, pry up the hinge panel.
  5. Dell XPS M1210 RAM Replacement: 5 단계, 이미지 1/3 Dell XPS M1210 RAM Replacement: 5 단계, 이미지 2/3 Dell XPS M1210 RAM Replacement: 5 단계, 이미지 3/3
    • Remove the 3 Phillips-head screws at the top of the keyboard.
    • After the 3 screws are removed, you will be able to lift the keyboard, exposing the top-side memory module slot.
    • The keyboard will still be connected to the computer, via a ribbon cable. The ribbon cable is long enough to place the keyboard out of the way ...disconnecting the ribbon cable is not necessary.
  6. Dell XPS M1210 RAM Replacement: 6 단계, 이미지 1/2 Dell XPS M1210 RAM Replacement: 6 단계, 이미지 2/2
    • Using your fingertips, spread apart the clips, which secure the memory module in place.
    • Secure the module with the clips, click it into place, and re-install the keyboard and hinge panel in reverse order of the above instructions.
결론
To reassemble your device, secure the module with the clips, click it into place, and reinstall the keyboard and hinge cover in reverse order of the above instructions.
다른 6명이 해당 안내서를 완성하였습니다.
Dave
회원 가입일: 01/25/15
226 평판
안내서 2개 작성하였습니다
Penn State, Team 1-100, Kaschak Winter 2015 Penn State, Team 1-100, Kaschak Winter 2015 회원
PSU-KASCHAK-W15S1G100
4 회원들
안내서 2개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 15
전체 시간: 1,877
