주요 콘텐츠로 건너뛰기
Dell XPS M1330 CPU Replacement
필요한 것
  1. Dell XPS M1330 CPU Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Flip the laptop on its back, so that the underside is facing up.
  2. Dell XPS M1330 CPU Replacement: 2 단계, 이미지 1개 중 1개
    • Push and hold the slide button to the left and unlock the mechanism.
  3. Dell XPS M1330 CPU Replacement: 3 단계, 이미지 2개 중 1개 Dell XPS M1330 CPU Replacement: 3 단계, 이미지 2개 중 2개
    • Lift the computer up and slowly pull the battery straight out from the device.
  4. Dell XPS M1330 CPU Replacement, Fan: 4 단계, 이미지 2개 중 1개 Dell XPS M1330 CPU Replacement, Fan: 4 단계, 이미지 2개 중 2개
    • Remove the four 5.0mm screws with a Phillips #1 screwdriver.
    • Remove the one external 5.0mm screw with a Phillips #1 screwdriver.
    • Remove the fan cover.
  5. Dell XPS M1330 CPU Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the four 0.1mm screws using the Phillips #1 screwdriver.
    • Remove the one thicker 0.1 mm screw using the Phillips #1 screwdriver.
  6. Dell XPS M1330 CPU Replacement: 6 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Be sure to carefully remove the wires as they are fragile and can rip easily.
    • Remove the wire bay near the fan.
    • Use the long nosed tweezers to carefully handle the white plastic piece that holds the wires together.
    • Gently pull upward while moving your hand side to side so the plastic holder will detach.
  7. Dell XPS M1330 CPU Replacement: 7 단계, 이미지 1개 중 1개
    • Gently remove the fan and its attachments from the bay.
  8. Dell XPS M1330 CPU Replacement, CPU: 8 단계, 이미지 1개 중 1개
    • Using the flathead screwdriver, turn the one screw counterclockwise to loosen the CPU, but do not remove the screw.
  9. Dell XPS M1330 CPU Replacement: 9 단계, 이미지 1개 중 1개
    • Using the iFixit opening tool, prop up the CPU.
  10. Dell XPS M1330 CPU Replacement: 10 단계, 이미지 1개 중 1개
    • Carefully lift the CPU away from its housing.
결론
작성자
2다른 기여자 명과 함께
Kai Kapossy
회원 가입일: 03/24/19
676 평판
안내서 5개를 작성함
UMass Dartmouth, Team S6-G2, Peak Spring 2019 UMass Dartmouth, Team S6-G2, Peak Spring 2019 회원
UMASSD-PEAK-S19S6G2
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 8
전체 시간: 897
