소개
This guide helps you to upgrade or replace your wireless card to a new Wi-Fi standard if you have determined that the reason your wireless internet is not working is because of a hardware issue with the card.
도구
부품
지정된 부품이 없습니다.
Unscrew the two 4.7mm Phillips #1 screws on the bottom panel of the laptop.
Two 4.7mm Philips #1 screws
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
