주요 콘텐츠로 건너뛰기
Dell XPS M170 MXG051 Memory Module Replacement
필요한 것
  1. Dell XPS M170 MXG051 Memory Module Replacement, Dell XPS M170 MXG051 Battery Removal: 1 단계, 이미지 1/1
    • Turn off your computer. Then, disconnect your computer and all attached devices from their electrical outlets.
    • Close the display and turn the computer upside down on a flat work surface.
    • Slide the battery-bay latch release on the bottom of the computer and remove the battery from the bay.
  2. Dell XPS M170 MXG051 Memory Module Replacement, Remove Memory Module Cover: 2 단계, 이미지 1/1
    • Loosen the two captive screws from the memory module cover, and remove the cover.
  3. Dell XPS M170 MXG051 Memory Module Replacement: 3 단계, 이미지 1/1
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the module pops up.
    • Remove the module(s) from the connector at a 45 - degree angle.
  4. Dell XPS M170 MXG051 Memory Module Replacement, Install New Memory: 4 단계, 이미지 1/1
    • Align the notch in the new memory module's edge connector with the tab in the connector slot.
    • Slide the module firmly into the slot at a 45 - degree angle, and press the the module down (so that it is horizontal. If you do not feel the memory module click into place after you press it down, remove the module and reinstall it.
  5. Dell XPS M170 MXG051 Memory Module Replacement: 5 단계, 이미지 1/1
    • Replace the memory cover and tighten the captive screws.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Johnathan Hammond
회원 가입일: 02/28/18
45,058 평판
안내서 408개 작성하였습니다
RampUP America, Inc. RampUP America, Inc. 회원
Community
42 회원들
안내서 1,984개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 107
