소개
This guide will demonstrate how to replace the memory for the Dell XPS M1710.
Ground yourself by touching one of the metal connectors on the back of the computer
Turn the computer over, loosen the captive screws on the memory module cover, and then remove the cover.
If you are replacing a memory module, remove the existing module:
Replace the memory module cover.
Insert the battery into the battery bay, or connect the AC adapter to your computer and an electrical outlet.
Turn on the computer.
As the computer boots, it detects the additional memory and automatically updates the system configuration information. If prompted, press <F1> to continue.
To confirm the amount of memory installed in the computer, click the Start button, click Help and Support, and then click Computer Information.
