주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell XPS M1710 RAM Replacement
필요한 것
  1. Dell XPS M1710 RAM Replacement, Disconnect the AC Adapter: 1 단계, 이미지 1개 중 1개
    • Nobody wants to get shocked while working on their electronics! Be safe and unplug the power.
  2. Dell XPS M1710 RAM Replacement, Remove the Battery: 2 단계, 이미지 1개 중 1개
    • You'll want to flip the laptop upside down, and you'll see the battery in the lower left corner (it has 5 lights on it with a battery icon, it's hard to miss).
    • To release the battery, pull the switch as far to the right as you can, and then use your fingers under the plastic grip to lift up the battery towards you.
  3. Dell XPS M1710 RAM Replacement, Remove the Memory Cover: 3 단계, 이미지 1개 중 1개
    • There are two Phillips screws that hold the cover on. As you loosen them, the cover will start to pop up on the left side.
    • Once the screws are loosened, use your fingers to gently pry under the plastic right where the white "M" is and the cover will pop right off.
  4. Dell XPS M1710 RAM Replacement, Removing the RAM: 4 단계, 이미지 1개 중 1개
    • You're almost there! Now it's just time to remove the RAM itself.
    • For each RAM stick, there are 2 retention clips that hold the RAM in. To release them, use your hands to pull each of the clips away from the RAM card, and the card will pop up, which then you can pull out of the slot.
    • To reinstall the RAM, be sure to insert the module at an angle similar to when the cards popped up, with the contacts inside the slot, then gently push them straight down until the retention clips pop back into place.
결론
To reassemble your device, follow these instructions in reverse order. See the note on Step 4 for help reinstalling the memory modules themselves.
작성자
3다른 기여자 명과 함께
Robert Thorpe
회원 가입일: 12/19/15
210 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 18
전체 시간: 744
