주요 콘텐츠로 건너뛰기
Dell XPS M1730 M1730 Hard Drive Replacement
필요한 것
    • If you remove the hard drive from the computer when the drive is hot, do not touch the metal housing of the hard drive.
    • To prevent data loss, turn off your computer before removing the hard drive. Do not remove the hard drive while the computer is on, in standby mode, or in hibernate mode.
    • Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Turn the computer over, loosen the two captive screws on the hard drive cover, and then remove the cover
    • Loosen the four captive screws on the hard drive cage and then lift the pull-tab to flip the cage towards the center of the computer so that the SATA cables and connectors are accessible
    • Carefully remove the SATA cables from the hard drive or drives that are installed in the cage
    • Remove two screws on each side of the hard drive cage to free the hard drive, then lift the drive out of its tray in the cage
    • NOTICE: When a hard drive is not in the computer, store it in protective antistatic packaging.
    • Remove the new hard drive from its packaging. Save the original packaging for storing or shipping the hard drive
    • Place the new hard drive into the drive cage tray and secure it with two screws on each side.
    • Install the hard drive so that the manufacturer’s label faces the bottom of the drive cage and the SATA connectors are at the open end of the cage
    • Install the primary hard drive in the tray labeled 0. You can install a secondary hard drive in the tray labeled 1.
결론
작성자
3다른 기여자 명과 함께
Amia Frazier
회원 가입일: 10/10/19
887 평판
안내서 7개를 작성함
RampUP America, Inc. RampUP America, Inc. 회원
Community
43 회원들
안내서 1,985개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 1
전체 시간: 100
