주요 콘텐츠로 건너뛰기
Delphi MyFi XM2GO Motherboard Replacement
필요한 것
  1. Delphi MyFi XM2GO Motherboard Replacement, Battery Cover: 1 단계, 이미지 1/3 Delphi MyFi XM2GO Motherboard Replacement, Battery Cover: 1 단계, 이미지 2/3 Delphi MyFi XM2GO Motherboard Replacement, Battery Cover: 1 단계, 이미지 3/3
    • Locate the large button on the top of the device.
    • Push down on the button and slide the cover away from the button.
    • The battery removal tab may pop up.
  2. Delphi MyFi XM2GO Motherboard Replacement, Battery: 2 단계, 이미지 1/3 Delphi MyFi XM2GO Motherboard Replacement, Battery: 2 단계, 이미지 2/3 Delphi MyFi XM2GO Motherboard Replacement, Battery: 2 단계, 이미지 3/3
    • Grab the red pull tab and pull down to unlock the latch.
    • Pull the battery out.
  3. Delphi MyFi XM2GO Motherboard Replacement, Motherboard: 3 단계, 이미지 1/2 Delphi MyFi XM2GO Motherboard Replacement, Motherboard: 3 단계, 이미지 2/2
    • Remove the four screws from the bottom of the device using a T6 Torx screwdriver.
  4. Delphi MyFi XM2GO Motherboard Replacement: 4 단계, 이미지 1/3 Delphi MyFi XM2GO Motherboard Replacement: 4 단계, 이미지 2/3 Delphi MyFi XM2GO Motherboard Replacement: 4 단계, 이미지 3/3
    • Remove the button cover on the back of the device by prying it up with a spudger or your thumb nail.
  5. Delphi MyFi XM2GO Motherboard Replacement: 5 단계, 이미지 1/3 Delphi MyFi XM2GO Motherboard Replacement: 5 단계, 이미지 2/3 Delphi MyFi XM2GO Motherboard Replacement: 5 단계, 이미지 3/3
    • Remove the two screws under the button using the T6 Torx screwdriver.
  6. Delphi MyFi XM2GO Motherboard Replacement: 6 단계, 이미지 1/2 Delphi MyFi XM2GO Motherboard Replacement: 6 단계, 이미지 2/2
    • Remove the back cover.
  7. Delphi MyFi XM2GO Motherboard Replacement: 7 단계, 이미지 1/2 Delphi MyFi XM2GO Motherboard Replacement: 7 단계, 이미지 2/2
    • Remove the power button by pulling it to the left.
  8. Delphi MyFi XM2GO Motherboard Replacement: 8 단계, 이미지 1/2 Delphi MyFi XM2GO Motherboard Replacement: 8 단계, 이미지 2/2
    • Remove the plastic antenna extension connector on the right side of the device.
  9. Delphi MyFi XM2GO Motherboard Replacement: 9 단계, 이미지 1/3 Delphi MyFi XM2GO Motherboard Replacement: 9 단계, 이미지 2/3 Delphi MyFi XM2GO Motherboard Replacement: 9 단계, 이미지 3/3
    • Pull up on the motherboard to remove it from the device.
    • The LCD screen and keypad are only connected to the motherboard with ribbon cables. They will hang down as the motherboard is removed.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Scott Byer
회원 가입일: 03/09/12
61 평판
안내서 5개 작성하였습니다
Clemson, Team 1-2, Benson Spring 2012 Clemson, Team 1-2, Benson Spring 2012 회원
CLEM-BENSON-S12S1G2
3 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 2,485
