소개
If your Delta Push Valve shower diverter is leaky, stuck into place, or needs to be replaced for any reason, this guide is for you. Your shower diverter plays an important role in diverting water back and forth between the tub faucet and the shower head.
A plumber visit can be costly, but the fix can be easy and save you time, stress, and money. This process should take 25 minutes max with a few simple tools no hazards on the job. The guide will walk you through how to disassemble your shower valve, replace the diverter, and put it all back together again in functioning order.
This guide works to repair or replace a Delta Push Valve style diverter, or a model RP5649. If you have a different type of diverter, this guide may not work for you.
필요한 것
Remove the decorative cap off of the knob by pushing a flathead screwdriver underneath the cap.
Test the water flow before leaving the project! If it is leaking, you may need to tighten the diverter or screws.
Once everything looks good, you’re done! Great job. You’ve saved yourself a visit from the plumber by fixing it yourself.
다른 3명이 해당 안내서를 완성하였습니다.
1가이드 댓글
Please turn on the water and engage the diverter. I want to see it work! I put in a new diverter and it did not completely divert ALL of the water. After installing the new diverter, about 10% - or so - of the water continued to come out of the faucet (and 90% was diverted up to the shower head). I'm not sure how to fix this problem. Perhaps, I will let a little water to flow out of the faucet, wasting water and electricity (to heat the water).
