필요한 것
Rota la impresora 90 grados a la derecha, para que el lado de panel correspondiente al panel de control esté frente a ti.
Remueve los dos tornillos Torx T10 de 12 mm del panel izquierdo.
Aparta el panel superior de la impresora.
Remueve los dos tornillos Torx T10 de 12 mm del frente superior de la impresora.
Para reensamblar tu dispositivo, sigue las instrucciones en orden inverso.
다른 12명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 2개
Thank You sooo much….Just what I needed
One of the 4 pins on this spring loaded plastic piece on the carriage farthest one to the right popped off and for some reason it raised up and was stopping the carriage from sliding left..So once I got the carriage off it dropped back down ,spring is fine so I snapped the pin back in…cool i thought it was broken…So I’ll clean it up put it back together and see what happens
Sure hope I can get those cables back in rite
I’ll let you know!!! >>—-@—->
Wpw its working
Got rid of the flashing orange light,carriage is sliding left an right ,printed a test page…WOOOHOOO!!!
Thank you all again so much
