주요 콘텐츠로 건너뛰기
Desk Drawer Hanging File Brace Bar Repair
필요한 것
  1. Desk Drawer Hanging File Brace Bar Repair, Desk Drawer Hanging File Brace Bar Repair: 1 단계, 이미지 1개 중 1개
    • Remove all content from the drawer. (If possible, remove the drawer from the desk for better accessibility).
    • Using the pencil, mark reference points where the brace bar is located at the top of the drawer.
  2. Desk Drawer Hanging File Brace Bar Repair: 2 단계, 이미지 1개 중 1개
    • Use the sandpaper and the wood file to sand the area until it is completely smooth to the touch.
    • This process needs to be done on both sides of the drawer where the brace bar was located.
  3. Desk Drawer Hanging File Brace Bar Repair: 3 단계, 이미지 2개 중 1개 Desk Drawer Hanging File Brace Bar Repair: 3 단계, 이미지 2개 중 2개
    • Apply the wood putty to the freshly sanded corners. Smooth the wood putty evenly, applying moderate pressure to ensure stable reinforcement.
  4. Desk Drawer Hanging File Brace Bar Repair: 4 단계, 이미지 1개 중 1개
    • Wait until the putty has almost completely dried (approximately 30 minutes), at which point use the reference points and replace the brace bar, sliding in from the top of the drawer.
  5. Desk Drawer Hanging File Brace Bar Repair: 5 단계, 이미지 1개 중 1개
    • Reinforce the brace bar once you have properly placed it in the drawer front with wood putty to ensure stability.
  6. Desk Drawer Hanging File Brace Bar Repair: 6 단계, 이미지 1개 중 1개
    • Replace the hanging files and enjoy your newly secured hanging file drawer.
결론
From this procedure you will have a stronger, reinforced hanging file brace bar.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Abbe Robb
회원 가입일: 09/13/15
173 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 18
전체 시간: 1,750
