주요 콘텐츠로 건너뛰기
Desktop PC Front Fan Replacement
필요한 것
  1. Desktop PC Front Fan Replacement, Left Panel: 1 단계, 이미지 1/1
    • Unplug the computer from the power supply before any maintenance or disassembly.
    • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
    • These screws can usually be removed by hand.
    • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
    This depends on the model of system. Some systems have a lever/latch to pull to release the cover. Many Dell and HP models use latches to open the covers (no tools required to open the system). Some systems need a screwdriver to remove the screws. Some are Phillips screws, others may be Torx.
    Dave Ellefson - 답글
    This is correct.
    DistroHopper39B -
  2. Desktop PC Front Fan Replacement: 2 단계, 이미지 1/2 Desktop PC Front Fan Replacement: 2 단계, 이미지 2/2
    • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
    • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
  3. Desktop PC Front Fan Replacement, Front Fan: 3 단계, 이미지 1/2 Desktop PC Front Fan Replacement, Front Fan: 3 단계, 이미지 2/2
    • Push to unlatch three grey connectors on the front panel.
  4. Desktop PC Front Fan Replacement: 4 단계, 이미지 1/1
    • Disconnect the front panel from the computer face.
  5. Desktop PC Front Fan Replacement: 5 단계, 이미지 1/1
    • Remove four Phillips #2 head, 5mm screws holding in the fan.
  6. Desktop PC Front Fan Replacement: 6 단계, 이미지 1/1
    • Slide the fan out from the side of the casing.
  7. Desktop PC Front Fan Replacement: 7 단계, 이미지 1/1
    • Disconnect the power cable from the fan.
결론
다른 38명이 해당 안내서를 완성하였습니다.
David Lennon
회원 가입일: 04/14/15
9,944 평판
안내서 10개 작성하였습니다
Cal Poly, Team 4-5, Maness Spring 2015 Cal Poly, Team 4-5, Maness Spring 2015 회원
CPSU-MANESS-S15S4G5
4 회원들
안내서 45개 작성하였습니다
댓글 한 개
My two bottom connecters holding the face of my pc case have screws in them. Problem is that I can't fit a screw driver in the gaps to remove the screws! Any tips?
Jimmy Jam - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 29
30일 전: 149
전체 시간: 27,357
