주요 콘텐츠로 건너뛰기
Desktop PC Graphics Card Replacement
필요한 것
  1. Desktop PC Graphics Card Replacement, Left Panel: 1 단계, 이미지 1/1
    • Unplug the computer from the power supply before any maintenance or disassembly.
    • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
    • These screws can usually be removed by hand.
    • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
    This depends on the model of system. Some systems have a lever/latch to pull to release the cover. Many Dell and HP models use latches to open the covers (no tools required to open the system). Some systems need a screwdriver to remove the screws. Some are Phillips screws, others may be Torx.
    Dave Ellefson - 답글
    This is correct.
    DistroHopper39B -
  2. Desktop PC Graphics Card Replacement: 2 단계, 이미지 1/2 Desktop PC Graphics Card Replacement: 2 단계, 이미지 2/2
    • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
    • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
  3. Desktop PC Graphics Card Replacement, Graphics Card: 3 단계, 이미지 1/1
    • Remove the Phillips #2 head, 5mm screw holding the graphics card in place.
    • Make sure that you have grounded yourself so that upon removal of the graphics card you do not accidentally shock the circuit board and damage it.
  4. Desktop PC Graphics Card Replacement: 4 단계, 이미지 1/2 Desktop PC Graphics Card Replacement: 4 단계, 이미지 2/2
    • Press the latch on the side of the connector area to unlock the graphics card, and carefully slide the graphics card out from its slot in the computer.
    • A good technique is to lay the computer onto it side, push the latch down and lift the graphics card out.
    Sur les ports récents, (PCIE) il y a d’abord l’encoche à éloigner pour permettre le retrait de carte graphique.
    benam - 답글
    most gpu's have screws so you MUST take them out first or the pins on the gpu and pci slot will crack.
    Dovber Levertov - 답글
결론
다른 78명이 해당 안내서를 완성하였습니다.
David Lennon
회원 가입일: 04/14/15
9,944 평판
안내서 10개 작성하였습니다
Cal Poly, Team 4-5, Maness Spring 2015 Cal Poly, Team 4-5, Maness Spring 2015 회원
CPSU-MANESS-S15S4G5
4 회원들
안내서 45개 작성하였습니다
댓글 3개
There should be a notice about the PCI-E slot, which has a security latch; the latch should be pressed in order to remove the graphics card from the motherboard.
Onel Jimenez - 답글
I have a all in one pc so this is not relevant
Robert Campanelli - 답글
any diffrerences in slots?
benzy aceware - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 65
30일 전: 224
전체 시간: 15,438
