주요 콘텐츠로 건너뛰기
소개
Removing the left panel of a desktop computer is an important skill to have for repair and troubleshooting purposes. The left panel must be removed before any repairs can be performed on the inside of the computer. In addition, computers with heating problems could benefit from having the left panel removed.
부품
지정된 부품이 없습니다.
  1. Desktop PC Left Panel Replacement, Left Panel: 1 단계, 이미지 1/1
    • Unplug the computer from the power supply before any maintenance or disassembly.
    • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
    • These screws can usually be removed by hand.
    • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
    This depends on the model of system. Some systems have a lever/latch to pull to release the cover. Many Dell and HP models use latches to open the covers (no tools required to open the system). Some systems need a screwdriver to remove the screws. Some are Phillips screws, others may be Torx.
    Dave Ellefson - 답글
    This is correct.
    DistroHopper39F -
  2. Desktop PC Left Panel Replacement: 2 단계, 이미지 1/2 Desktop PC Left Panel Replacement: 2 단계, 이미지 2/2
    • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
    • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
결론
다른 21명이 해당 안내서를 완성하였습니다.
David Lennon
회원 가입일: 2015년 04월 14일
9,650 평판
안내서 10개 작성하였습니다
Cal Poly, Team 4-5, Maness Spring 2015 Cal Poly, Team 4-5, Maness Spring 2015 회원
CPSU-MANESS-S15S4G5
4 회원들
안내서 29개 작성하였습니다
3 Comments
What is the name of the case used in this tutorial?
Nicolas Hunter - 답글
I would also like to know, I saved one of these from a junk pile but not sure what it is? Was able to fit a full ATX board with gtx570 and a little breathing room so not too shabby for how small it is.
Wabbajack Wabbajack - 답글
I have this same case in black and want to know what model it is.
numanair - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 18
30일 전: 105
전체 시간: 3,987
