주요 콘텐츠로 건너뛰기
Asus Eee PC 1015PN motherboard dismantling (English)
필요한 것
  1. Asus Eee PC 1015PN  motherboard dismantling (English), Motherboard: 1 단계, 이미지 1/2 Asus Eee PC 1015PN  motherboard dismantling (English), Motherboard: 1 단계, 이미지 2/2
    • To remove the battery, unlock the marked tabs.
  2. Asus Eee PC 1015PN  motherboard dismantling (English): 2 단계, 이미지 1/3 Asus Eee PC 1015PN  motherboard dismantling (English): 2 단계, 이미지 2/3 Asus Eee PC 1015PN  motherboard dismantling (English): 2 단계, 이미지 3/3
    • To remove the memory, lift the plastic tab covering the memory screw with a small slot head screwdriver.
  3. Asus Eee PC 1015PN  motherboard dismantling (English): 3 단계, 이미지 1/2 Asus Eee PC 1015PN  motherboard dismantling (English): 3 단계, 이미지 2/2
    • Lift the plastic cover and remove the SO-DIMM module.
  4. Asus Eee PC 1015PN  motherboard dismantling (English): 4 단계, 이미지 1/2 Asus Eee PC 1015PN  motherboard dismantling (English): 4 단계, 이미지 2/2
    • Remove the dummy SD-Card
  5. Asus Eee PC 1015PN  motherboard dismantling (English): 5 단계, 이미지 1/2 Asus Eee PC 1015PN  motherboard dismantling (English): 5 단계, 이미지 2/2
    • Unscrew 4 screws that are located in the battery compartment. Once removed, plastic tabs need to be removed on the upper part.
  6. Asus Eee PC 1015PN  motherboard dismantling (English): 6 단계, 이미지 1/2 Asus Eee PC 1015PN  motherboard dismantling (English): 6 단계, 이미지 2/2
    • With an extraction tool, separate the keyboard chassis from the netbook, it has many tabs.
  7. Asus Eee PC 1015PN  motherboard dismantling (English): 7 단계, 이미지 1/2 Asus Eee PC 1015PN  motherboard dismantling (English): 7 단계, 이미지 2/2
    • While separating the keyboard chassis, be careful with the keyboard connector. To remove it, simply slide the plastic retainer to be able to free it.
  8. Asus Eee PC 1015PN  motherboard dismantling (English): 8 단계, 이미지 1/2 Asus Eee PC 1015PN  motherboard dismantling (English): 8 단계, 이미지 2/2
    • Unscrew the marked screws. One of those screws is behind a warranty sticker.
  9. Asus Eee PC 1015PN  motherboard dismantling (English): 9 단계, 이미지 1/2 Asus Eee PC 1015PN  motherboard dismantling (English): 9 단계, 이미지 2/2
    • Disconnect the mouse connector. The connector has a white plastic tab that disconnects the connector.
  10. Asus Eee PC 1015PN  motherboard dismantling (English): 10 단계, 이미지 1/3 Asus Eee PC 1015PN  motherboard dismantling (English): 10 단계, 이미지 2/3 Asus Eee PC 1015PN  motherboard dismantling (English): 10 단계, 이미지 3/3
    • With a flat screwdriver, release two plastic tabs ( 1 on each side), and with pressure in the front, release the chassis.
  11. Asus Eee PC 1015PN  motherboard dismantling (English): 11 단계, 이미지 1/2 Asus Eee PC 1015PN  motherboard dismantling (English): 11 단계, 이미지 2/2
    • To disconnect the hard drive, two connectors need to be removed, pay attention to the connectors sides, the one on the left in marked as MB and the right is marked as IO.
  12. Asus Eee PC 1015PN  motherboard dismantling (English): 12 단계, 이미지 1/3 Asus Eee PC 1015PN  motherboard dismantling (English): 12 단계, 이미지 2/3 Asus Eee PC 1015PN  motherboard dismantling (English): 12 단계, 이미지 3/3
    • Remove the screws, and slide the hard drive free.
  13. Asus Eee PC 1015PN  motherboard dismantling (English): 13 단계, 이미지 1/1
    • Disconnect the motherboard connector and the IO plate.
  14. Asus Eee PC 1015PN  motherboard dismantling (English): 14 단계, 이미지 1/2 Asus Eee PC 1015PN  motherboard dismantling (English): 14 단계, 이미지 2/2
    • Remove the fan connector, the BIOS battery and the upper connector.
  15. Asus Eee PC 1015PN  motherboard dismantling (English): 15 단계, 이미지 1/3 Asus Eee PC 1015PN  motherboard dismantling (English): 15 단계, 이미지 2/3 Asus Eee PC 1015PN  motherboard dismantling (English): 15 단계, 이미지 3/3
    • Remove the plate screws and release the screen connector.
  16. Asus Eee PC 1015PN  motherboard dismantling (English): 16 단계, 이미지 1/2 Asus Eee PC 1015PN  motherboard dismantling (English): 16 단계, 이미지 2/2
    • Remove the motherboard from the chassis, and disconnect a connector that is glued.
결론
다른 6명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
es en
100%
DeZom님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Jorge Casal Lopez
회원 가입일: 05/09/13
313 평판
안내서 1개 작성함
댓글 2개
Joder la que hay que liar para cambiar el disco duro.
Rafael Belmonte - 답글
Thank you for the guide
ilcaccillo - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 45
전체 시간: 13,693
