주요 콘텐츠로 건너뛰기
Motorola RFS4000 Disassembly
  1. Motorola RFS4000 Disassembly, Removing the screw: 1 단계, 이미지 1/3 Motorola RFS4000 Disassembly, Removing the screw: 1 단계, 이미지 2/3 Motorola RFS4000 Disassembly, Removing the screw: 1 단계, 이미지 3/3
    • Screw
    • Torx T8
    • If you don't have a Torx T8 screwdriver you can use a slotted screwdriver
  2. Motorola RFS4000 Disassembly, Opening the chassis: 2 단계, 이미지 1/2 Motorola RFS4000 Disassembly, Opening the chassis: 2 단계, 이미지 2/2
    • Slide up the cover
    • Fan cable
    • Before unscrew you must disconnect the fan cable.
  3. Motorola RFS4000 Disassembly, Removing the fan: 3 단계, 이미지 1/3 Motorola RFS4000 Disassembly, Removing the fan: 3 단계, 이미지 2/3 Motorola RFS4000 Disassembly, Removing the fan: 3 단계, 이미지 3/3
    • Fan chassis screws
    • Fan screws
    • Reset Button
    • Power Inlet
  4. Motorola RFS4000 Disassembly, Removing the motherboard: 4 단계, 이미지 1/3 Motorola RFS4000 Disassembly, Removing the motherboard: 4 단계, 이미지 2/3 Motorola RFS4000 Disassembly, Removing the motherboard: 4 단계, 이미지 3/3
    • Motherboard screws
    • RJ45 ports
    • Console port (rj45) and usb port
    • Express card
    • SFP port (Motorola part number: Fiber-3000-1S-WWR)
    • Reset button
결론
Para reensamblar tu dispositivo, sigue estas instrucciones en orden inverso.
다른 한 분이 해당 안내서를 완성하였습니다.
Eneider Colina
회원 가입일: 09/20/13
2,362 평판
안내서 9개 작성하였습니다
Comunidad para traductores de español Comunidad para traductores de español 회원
Community
24 회원들
안내서 246개 작성하였습니다
댓글 한 개
No, it's better not to use a slotted screwdriver, because the screws are tightened quite tight (if they haven't already been unscrewed) and you destroy the screws with them. Time required 30 minutes :-))? 10-15 maybe
omanoman - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 5
전체 시간: 272
