주요 콘텐츠로 건너뛰기
Detach the Behringer Eurolive B212D Electronics Box
필요한 것
  1. Detach the Behringer Eurolive B212D Electronics Box, Removing the Behringer Eurolive B212D Electronics Box: 1 단계, 이미지 1/1
    • CAUTION: Unplug your speaker from the power outlet.
    • Remove the 8 Phillips screws from the back of the speaker.
  2. Detach the Behringer Eurolive B212D Electronics Box: 2 단계, 이미지 1/1
    • Carefully remove the back panel, lifting out the metal electronics-box with it.
    • To avoid damaging your speaker, remove slowly, as there is still a wire attached from the electronics box to the speaker.
  3. Detach the Behringer Eurolive B212D Electronics Box, Detach the Behringer Eurolive B212D Electronics Box: 3 단계, 이미지 1/3 Detach the Behringer Eurolive B212D Electronics Box, Detach the Behringer Eurolive B212D Electronics Box: 3 단계, 이미지 2/3 Detach the Behringer Eurolive B212D Electronics Box, Detach the Behringer Eurolive B212D Electronics Box: 3 단계, 이미지 3/3
    • There are two silver, 6 mm-long machine screws with two 1/8" inner-diameter washers on the exterior of the metal electronics box; remove these first using a #2 philips screwdriver.
    • There are five of the same type of machine screw (silver, 6 mm-long) remaining around the metal electronics box's exterior; remove these as well.
    • You should have removed a total of 7 machine screws and 2 washers.
    • The reason for removing the two screws with the two washers first (or replacing them last when reassembling) is that their holes are actually slots. They are designed as slots to accommodate slop in the assembly, and if unscrewed out of order, you may have difficulty while removing - or possibly even damage - the other five screws.
  4. Detach the Behringer Eurolive B212D Electronics Box: 4 단계, 이미지 1/1
    • Remove the portion of the metal housing that you freed with the 7 screws in the previous step.
  5. Detach the Behringer Eurolive B212D Electronics Box: 5 단계, 이미지 1/3 Detach the Behringer Eurolive B212D Electronics Box: 5 단계, 이미지 2/3 Detach the Behringer Eurolive B212D Electronics Box: 5 단계, 이미지 3/3
    • Inside the metal electronics box housing is a white clip attached to a small PCB; remove this.
    • The white clip in this image has been glued, indicating that the manufacturer may not expect the end user to remove this clip; it is difficult to proceed with the disassembling without doing so, however, because the rest of the speaker does not provide a sufficient surface on which to work.
    • Snake the clip head through the hole in the metal electronics box casing.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Troy W. Weber
회원 가입일: 03/29/12
1,431 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 11
전체 시간: 2,526
