주요 콘텐츠로 건너뛰기
Dewalt Air Compressor DWFP55126 2016 Pump Replacement
필요한 것
  1. Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove manifold cover: 1 단계, 이미지 1/3 Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove manifold cover: 1 단계, 이미지 2/3 Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove manifold cover: 1 단계, 이미지 3/3
    • Disconnect the power cord, depressurize the compressor tank, and remove any hoses before starting this repair.
    • Use a long-shank T10 driver to remove the manifold cover screw.
    • Lift the cover directly up off of the gauges to remove.
  2. Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove handle: 2 단계, 이미지 1/2 Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove handle: 2 단계, 이미지 2/2
    • Use a T20 driver to remove the two handle screws, one on each side.
  3. Dewalt Air Compressor DWFP55126 2016 Pump Replacement: 3 단계, 이미지 1/3 Dewalt Air Compressor DWFP55126 2016 Pump Replacement: 3 단계, 이미지 2/3 Dewalt Air Compressor DWFP55126 2016 Pump Replacement: 3 단계, 이미지 3/3
    • Grab the handle like you would if you were to pick the compressor up. Pull up and push forward away from the gauges at the same time to rotate the handle up off the case.
    • Lift the handle off to remove.
  4. Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove top case: 4 단계, 이미지 1/3 Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove top case: 4 단계, 이미지 2/3 Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove top case: 4 단계, 이미지 3/3
    • Remove the following four screws:
    • Three 20 mm-long T20 screws.
    • One 20 mm-long Phillips #1 screw.
  5. Dewalt Air Compressor DWFP55126 2016 Pump Replacement: 5 단계, 이미지 1/2 Dewalt Air Compressor DWFP55126 2016 Pump Replacement: 5 단계, 이미지 2/2
    • Four metal tabs on the tank sit in four slots on the top plastic case to secure the case to the tank.
    • Firmly push the top case off of the four tabs to detach.
  6. Dewalt Air Compressor DWFP55126 2016 Pump Replacement: 6 단계, 이미지 1/3 Dewalt Air Compressor DWFP55126 2016 Pump Replacement: 6 단계, 이미지 2/3 Dewalt Air Compressor DWFP55126 2016 Pump Replacement: 6 단계, 이미지 3/3
    • Carefully pull the half of the case that is opposite the manifold away from the tank.
    • The motor may shift once the case is removed, but it won't fall out.
    • Reassembly tip: align the power cord in the cord cutout so it doesn't get pinched.
  7. Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove power switch: 7 단계, 이미지 1/3 Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove power switch: 7 단계, 이미지 2/3 Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove power switch: 7 단계, 이미지 3/3
    • Use a large flathead screwdriver to depress the plastic tab on the red power switch closest to the open side of the case.
    • While keeping the tab depressed, grab the top side of the switch and pull directly up off the case.
    • Pull the switch farther out of the case.
    • Don't try to completely remove the switch; there are still wires attached below.
  8. Dewalt Air Compressor DWFP55126 2016 Pump Replacement: 8 단계, 이미지 1/2 Dewalt Air Compressor DWFP55126 2016 Pump Replacement: 8 단계, 이미지 2/2
    • Use a flathead screwdriver to pry both wire connectors slightly off the plugs on the bottom of the switch.
  9. Dewalt Air Compressor DWFP55126 2016 Pump Replacement: 9 단계, 이미지 1/2 Dewalt Air Compressor DWFP55126 2016 Pump Replacement: 9 단계, 이미지 2/2
    • Once the wires are loosened from the plugs on the switch, completely remove both wires.
    • Remove the power switch.
  10. Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove ground wire: 10 단계, 이미지 1/2 Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove ground wire: 10 단계, 이미지 2/2
    • Carefully pull to remove the connector on the ground wire located inside the case.
  11. Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove check valve hose: 11 단계, 이미지 1/3 Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove check valve hose: 11 단계, 이미지 2/3 Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove check valve hose: 11 단계, 이미지 3/3
    • Use needle nose pliers to bend the check valve hose clamp up away from the hose.
    • Once the hose clamp is bent enough to clear the hose, lift it up and off to remove.
    • We strongly suggest you replace this hose clamp during reassembly to prevent leaks during operation.
  12. Dewalt Air Compressor DWFP55126 2016 Pump Replacement: 12 단계, 이미지 1/2 Dewalt Air Compressor DWFP55126 2016 Pump Replacement: 12 단계, 이미지 2/2
    • Pull the hose off the fitting to remove.
  13. Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove pump assembly: 13 단계, 이미지 1/2 Dewalt Air Compressor DWFP55126 2016 Pump Replacement, Remove pump assembly: 13 단계, 이미지 2/2
    • While holding the plastic housing, pull the pump assembly out, careful to not snag hoses or wires.
결론
Carsten Frauenheim
회원 가입일: 03/10/20
114,572 평판
안내서 339개 작성하였습니다
iFixit iFixit 회원
Staff
136 회원들
안내서 17,298개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 15
30일 전: 60
전체 시간: 2,530
