주요 콘텐츠로 건너뛰기
Dewalt DCD778 Clutch Replacement
필요한 것
  1. Dewalt DCD778 Clutch  Replacement, Battery: 1 단계, 이미지 1/1
    • Grab the drill in one hand and cup the battery (located at the bottom of the drill) with the other hand.
  2. Dewalt DCD778 Clutch  Replacement: 2 단계, 이미지 1/1
    • Use your other hand to push down on the yellow button on the battery.
  3. Dewalt DCD778 Clutch  Replacement: 3 단계, 이미지 1/1
    • Pull the battery in a horizontal direction away from the drill.
  4. Dewalt DCD778 Clutch  Replacement, Clutch: 4 단계, 이미지 1/2 Dewalt DCD778 Clutch  Replacement, Clutch: 4 단계, 이미지 2/2
    • Remove the eight 16 mm, Torx Security #15 screws.
  5. Dewalt DCD778 Clutch  Replacement: 5 단계, 이미지 1/1
    • Lay the drill on its side and gently lift the top half off it.
  6. Dewalt DCD778 Clutch  Replacement: 6 단계, 이미지 1/1
    • Lift drill mechanism from the drill assembly.
  7. Dewalt DCD778 Clutch  Replacement: 7 단계, 이미지 1/3 Dewalt DCD778 Clutch  Replacement: 7 단계, 이미지 2/3 Dewalt DCD778 Clutch  Replacement: 7 단계, 이미지 3/3
    • Twist slightly and pull clutch away from motor.
    • Remove clutch.
결론
Brittany
회원 가입일: 03/09/19
693 평판
안내서 5개 작성하였습니다
Casper College, Team S1-G5, Lareau Spring 2019 Casper College, Team S1-G5, Lareau Spring 2019 회원
CASC-LAREAU-S19S1G5
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 21
30일 전: 76
전체 시간: 2,476
