주요 콘텐츠로 건너뛰기
Dewalt DCF885 Brush Assembly Replacement
필요한 것
  1. Dewalt DCF885 Brush Assembly Replacement, Battery: 1 단계, 이미지 1/1
    • Press the battery release button at the top of the battery.
  2. Dewalt DCF885 Brush Assembly Replacement: 2 단계, 이미지 1/1
    • Pull the battery away from the tool.
  3. Dewalt DCF885 Brush Assembly Replacement, Motor Assembly: 3 단계, 이미지 1/1
    • Remove the eight 18 mm Torx Security #10 screws.
  4. Dewalt DCF885 Brush Assembly Replacement: 4 단계, 이미지 1/1
    • Separate the two halves of the outer case. Set the empty side down and out of the way.
  5. Dewalt DCF885 Brush Assembly Replacement: 5 단계, 이미지 1/1
    • Disconnect the connector from the motor assembly.
  6. Dewalt DCF885 Brush Assembly Replacement: 6 단계, 이미지 1/1
    • Pull the motor away from the brush assembly.
  7. Dewalt DCF885 Brush Assembly Replacement, Brush Assembly: 7 단계, 이미지 1/1
    • Lift the brush assembly out of the drill case.
  8. Dewalt DCF885 Brush Assembly Replacement: 8 단계, 이미지 1/1
    • Pull the armature assembly apart from the brush ring assembly.
  9. Dewalt DCF885 Brush Assembly Replacement: 9 단계, 이미지 1/1
    • Pry the two circled connectors apart from the brush ring assembly.
  10. Dewalt DCF885 Brush Assembly Replacement: 10 단계, 이미지 1/1
    • The brush assembly is now removed from the drill body.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Landon Smith
회원 가입일: 01/17/19
211 평판
안내서 1개 작성함
댓글 한 개
Can you tell me the exact model number of the unit in this tutorial? And/Or the part number for that switch assembly? I cannot find that specific switch assembly anywhere! Thank you.
Derek Tombrello - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 35
전체 시간: 2,304
