주요 콘텐츠로 건너뛰기
Dexcom G6 Receiver Charging Port Replacement
필요한 것
  1. Dexcom G6 Receiver Charging Port Replacement, Display and Front Bezel: 1 단계, 이미지 1개 중 1개
    • Unscrew the 6 Torx T5 screws from the back of the device
  2. Dexcom G6 Receiver Charging Port Replacement: 2 단계, 이미지 2개 중 1개 Dexcom G6 Receiver Charging Port Replacement: 2 단계, 이미지 2개 중 2개
    • Use a spudger to lift up the screen assembly ribbon cable flap, then remove the ribbon cable.
    • Screen Information: Model AM0310R-04 Lot # NHT18080052
  3. Dexcom G6 Receiver Charging Port Replacement, Charging Port: 3 단계, 이미지 1개 중 1개
    • Using a spudger, unplug the Charging Port connector from the motherboard.
  4. Dexcom G6 Receiver Charging Port Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the 2 silver Torx T5 screws holding the charging port down.
  5. Dexcom G6 Receiver Charging Port Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the Charging Port Assembly from the motherboard.
결론
작성자
1다른 기여자 명과 함께
Andrew S
회원 가입일: 07/30/21
15,453 평판
안내서 8개를 작성함
5가이드 댓글
Where can the part be purchased?
Mayor of Koala Corner - 답글
I'm not sure if there is a replacement charging port assembly available online. If you're good at microsoldering, you could replace the surface mount micro USB port on the assembly.
Andrew S -
where can the part be purchased?
would a cell phone repair shop be able to do this?
Ron Magliacane - 답글
If they are comfortable with it. Tell them it will probably require microsoldering.
Andrew S -
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 41
전체 시간: 1,002
