주요 콘텐츠로 건너뛰기
Dexcom G6 Receiver Display and Front Bezel Replacement
필요한 것
  1. Dexcom G6 Receiver Display and Front Bezel Replacement, Display and Front Bezel: 1 단계, 이미지 1개 중 1개
    • Unscrew the 6 Torx T5 screws from the back of the device
  2. Dexcom G6 Receiver Display and Front Bezel Replacement: 2 단계, 이미지 2개 중 1개 Dexcom G6 Receiver Display and Front Bezel Replacement: 2 단계, 이미지 2개 중 2개
    • Use a spudger to lift up the screen assembly ribbon cable flap, then remove the ribbon cable.
    • Screen Information: Model AM0310R-04 Lot # NHT18080052
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Andrew S
회원 가입일: 07/30/21
15,453 평판
안내서 8개를 작성함
7가이드 댓글
Where can the replacement parts be found? And a charging port?
Ron Magliacane - 답글
Also looking 2 the display. Have 2 dexcom receivers here and both with broken displays.
Jeroen - 답글
I'm not sure if you can find the displays anywhere. The only number (presumably model number) I could find on the screen was AM0310R-04 and the Lot Number NHT18080052.
Andrew S -
Sharewith us where we can find the displays to buy
Jeroen - 답글
I need assistance on a little project I’m working on requiring the display out of the dexcom receiver
Gregory Bassett - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 22
전체 시간: 1,485
