주요 콘텐츠로 건너뛰기
Dexcom G6 Receiver Speaker Replacement
필요한 것
  1. Dexcom G6 Receiver Speaker Replacement, Display and Front Bezel: 1 단계, 이미지 1개 중 1개
    • Unscrew the 6 Torx T5 screws from the back of the device
  2. Dexcom G6 Receiver Speaker Replacement: 2 단계, 이미지 2개 중 1개 Dexcom G6 Receiver Speaker Replacement: 2 단계, 이미지 2개 중 2개
    • Use a spudger to lift up the screen assembly ribbon cable flap, then remove the ribbon cable.
    • Screen Information: Model AM0310R-04 Lot # NHT18080052
  3. Dexcom G6 Receiver Speaker Replacement, Charging Port: 3 단계, 이미지 1개 중 1개
    • Using a spudger, unplug the Charging Port connector from the motherboard.
  4. Dexcom G6 Receiver Speaker Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the 2 silver Torx T5 screws holding the charging port down.
  5. Dexcom G6 Receiver Speaker Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the Charging Port Assembly from the motherboard.
  6. Dexcom G6 Receiver Speaker Replacement, Motherboard: 6 단계, 이미지 1개 중 1개
    • Remove the silver Torx T5 screw holding the motherboard down.
  7. Dexcom G6 Receiver Speaker Replacement: 7 단계, 이미지 2개 중 1개 Dexcom G6 Receiver Speaker Replacement: 7 단계, 이미지 2개 중 2개
    • Using a spudger, carefully remove the battery connector on the left side of the motherboard.
  8. Dexcom G6 Receiver Speaker Replacement: 8 단계, 이미지 1개 중 1개
    • Using a spudger, carefully pry up the motherboard to remove it.
  9. Dexcom G6 Receiver Speaker Replacement, Speaker: 9 단계, 이미지 1개 중 1개
    • Using a spudger, carefully pry up and remove the speaker at the top.
    • Remove any remaining adhesive.
    • Put down new adhesive tape(be careful not to let it get in the way of the speaker).
    • Stick the new speaker down.
결론
작성자
1다른 기여자 명과 함께
Andrew S
회원 가입일: 07/30/21
15,453 평판
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 4
전체 시간: 236
