주요 콘텐츠로 건너뛰기
Dexter 220W Wired Multifunction Sander - 220MFS2.5 Stabiliser Replacement
필요한 것
  1. Dexter 220W Wired Multifunction Sander - 220MFS2.5 Stabiliser Replacement, Unplug: 1 단계, 이미지 1/1
    • Before starting, remember to disconnect the outlet from the mains.
  2. Dexter 220W Wired Multifunction Sander - 220MFS2.5 Stabiliser Replacement: 2 단계, 이미지 1/1
    • Remove the seal on the back of the device.
  3. Dexter 220W Wired Multifunction Sander - 220MFS2.5 Stabiliser Replacement: 3 단계, 이미지 1/3 Dexter 220W Wired Multifunction Sander - 220MFS2.5 Stabiliser Replacement: 3 단계, 이미지 2/3 Dexter 220W Wired Multifunction Sander - 220MFS2.5 Stabiliser Replacement: 3 단계, 이미지 3/3
    • Unscrew the first screw from the pad.
    • Then unscrew the remaining four screws and pull up to remove it.
    • Finally, remove the screws located on the shell of the device.
    • To remove the stabilisers you must leverage with a screwdriver.
    • To reset the new stabiliser, you just have to reposition it in your home.
  4. Dexter 220W Wired Multifunction Sander - 220MFS2.5 Stabiliser Replacement: 6 단계, 이미지 1/2 Dexter 220W Wired Multifunction Sander - 220MFS2.5 Stabiliser Replacement: 6 단계, 이미지 2/2
    • Replace the hull of the sander, taking care to properly position the stabilisers in their housings.
  5. Dexter 220W Wired Multifunction Sander - 220MFS2.5 Stabiliser Replacement: 7 단계, 이미지 1/3 Dexter 220W Wired Multifunction Sander - 220MFS2.5 Stabiliser Replacement: 7 단계, 이미지 2/3 Dexter 220W Wired Multifunction Sander - 220MFS2.5 Stabiliser Replacement: 7 단계, 이미지 3/3
    • Replace the pad by positioning it perfectly in the tips.
    • Screw the four screws
    • Then the last screw. Finally, put the joint back in its place.
결승점
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
HelloMacOS님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Céline Chemineau
회원 가입일: 01/29/20
16,581 평판
안내서 95개 작성하였습니다
Leroy Merlin Leroy Merlin 회원
Community
36 회원들
안내서 239개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 214
