주요 콘텐츠로 건너뛰기
Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser
필요한 것
  1. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser, Unplug: 1 단계, 이미지 1/1
    • Before starting, remember to disconnect the outlet from the mains.
  2. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser: 2 단계, 이미지 1/2 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser: 2 단계, 이미지 2/2
    • Remove the dust case on the back of the device.
  3. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser: 3 단계, 이미지 1/3 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser: 3 단계, 이미지 2/3 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser: 3 단계, 이미지 3/3
    • Unscrew the six screws from the pad.
    • Lock the motor with a screwdriver to be able to unscrew the centre screw, you will not be able to get there without blocking the gear.
  4. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser: 4 단계, 이미지 1/2 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser: 4 단계, 이미지 2/2
    • Remove the four stabilisers by hand.
  5. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser: 5 단계, 이미지 1/2 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser: 5 단계, 이미지 2/2
    • The stabilisers make sense, so be careful when replacing them.
    • Replace them directly on the pad for ease.
  6. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser: 6 단계, 이미지 1/2 Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser: 6 단계, 이미지 2/2
    • Reposition the part, then lock the engine with a screwdriver to screw.
    • Put the tray back on and screw the screws.
  7. Dexter 330W Wired Vibrating Sander - 330SHS2.5 Replacement Stabiliser: 7 단계, 이미지 1/1
    • Finally, reposition the vacuum bag.
결승점
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
HelloMacOS님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Céline Chemineau
회원 가입일: 01/29/20
16,581 평판
안내서 95개 작성하였습니다
Leroy Merlin Leroy Merlin 회원
Community
36 회원들
안내서 239개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 15
전체 시간: 373
