주요 콘텐츠로 건너뛰기
Dexter 750W Corded Jigsaw Motor Replacement
필요한 것
  1. Dexter 750W Corded Jigsaw Motor Replacement, Unplug: 1 단계, 이미지 1개 중 1개
    • Before you begin, remember to disconnect the mains plug.
  2. Dexter 750W Corded Jigsaw Motor Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the vacuum adapter from the back of the device.
  3. Dexter 750W Corded Jigsaw Motor Replacement: 3 단계, 이미지 2개 중 1개 Dexter 750W Corded Jigsaw Motor Replacement: 3 단계, 이미지 2개 중 2개
    • Using a screwdriver or screwdriver, unscrew and open the device.
    • Unlock the tray by lifting the lever.
    • Use needle nose pliers and remove the clip located next to the blade holder.
    • Remove the blade holder, keeping the slider at the end of the holder.
  4. Dexter 750W Corded Jigsaw Motor Replacement: 6 단계, 이미지 1개 중 1개
    • Unscrew the two screws and set them aside.
    • Remove the two carbons located next to the stator.
    • Lift the stator, then lever out the motor.
  5. Dexter 750W Corded Jigsaw Motor Replacement: 9 단계, 이미지 1개 중 1개
    • Put the new motor back in its place.
  6. Dexter 750W Corded Jigsaw Motor Replacement: 10 단계, 이미지 2개 중 1개 Dexter 750W Corded Jigsaw Motor Replacement: 10 단계, 이미지 2개 중 2개
    • Collect the end cap on the old engine.
    • Put it back on the new motor.
    • Put some grease on the tip.
  7. Dexter 750W Corded Jigsaw Motor Replacement: 11 단계, 이미지 1개 중 1개
    • Replace the two screws to stabilize the motor.
    • Return the blade holder to its location
    • Make sure you put each piece in its place.
    • Replace the staple in the same location. The curved side of the staple should go to the rounded side of the bracket.
    • Lubricate the whole
  8. Dexter 750W Corded Jigsaw Motor Replacement: 14 단계, 이미지 2개 중 1개 Dexter 750W Corded Jigsaw Motor Replacement: 14 단계, 이미지 2개 중 2개
    • Put the coals back in their places.
  9. Dexter 750W Corded Jigsaw Motor Replacement: 15 단계, 이미지 1개 중 1개
    • Before closing, lubricate each gear.
  10. Dexter 750W Corded Jigsaw Motor Replacement: 16 단계, 이미지 1개 중 1개
    • Close and screw the device.
결론
follow guide through or in reverse to reassemble
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
HelloMacOS님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
작성자
1다른 기여자 명과 함께
Céline Chemineau
회원 가입일: 01/29/20
17,013 평판
안내서 95개를 작성함
Leroy Merlin Leroy Merlin 회원
Community
38 회원들
안내서 248개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 17
전체 시간: 771
