주요 콘텐츠로 건너뛰기
Dexter 750W Switch Replacement Corded Jigsaw
필요한 것
  1. Dexter 750W Switch Replacement Corded Jigsaw, Unplug: 1 단계, 이미지 1개 중 1개
    • Before you begin, remember to disconnect the mains plug.
  2. Dexter 750W Switch Replacement Corded Jigsaw: 2 단계, 이미지 1개 중 1개
    • Remove the vacuum adapter from the back of the device.
  3. Dexter 750W Switch Replacement Corded Jigsaw: 3 단계, 이미지 2개 중 1개 Dexter 750W Switch Replacement Corded Jigsaw: 3 단계, 이미지 2개 중 2개
    • Using a screwdriver or screwdriver, unscrew and open the device.
    • Unlock the tray by lifting the lever.
  4. Dexter 750W Switch Replacement Corded Jigsaw: 4 단계, 이미지 1개 중 1개
    • Remove the black screw, in order to remove the knob.
    • Using a screwdriver, pry to be able to recover the wheel.
  5. Dexter 750W Switch Replacement Corded Jigsaw: 6 단계, 이미지 1개 중 1개
    • Turn over the switch, to be able to access the screw.
  6. Dexter 750W Switch Replacement Corded Jigsaw: 7 단계, 이미지 1개 중 1개
    • Remove the four screws to be able to unlock the system and remove the wires.
  7. Dexter 750W Switch Replacement Corded Jigsaw: 8 단계, 이미지 2개 중 1개 Dexter 750W Switch Replacement Corded Jigsaw: 8 단계, 이미지 2개 중 2개
    • Replace the new switch and reseat the wires. Be careful to put each wire back in its place.
    • Following the picture, the red wire is at the top left, the blue wire at the top right, the blue and black wire at the bottom left, and the brown wire at the bottom right.
    • The cables must be placed below so as not to interfere with the closure and must not protrude.
  8. Dexter 750W Switch Replacement Corded Jigsaw: 9 단계, 이미지 1개 중 1개
    • Put the wheel back in its housing and screw it back on.
  9. Dexter 750W Switch Replacement Corded Jigsaw: 10 단계, 이미지 1개 중 1개
    • Close and screw the device.
결론
follow guide through or in reverse to reassemble
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
HelloMacOS님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
작성자
1다른 기여자 명과 함께
Céline Chemineau
회원 가입일: 01/29/20
17,013 평판
안내서 95개를 작성함
Leroy Merlin Leroy Merlin 회원
Community
38 회원들
안내서 248개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 5
전체 시간: 334
