주요 콘텐츠로 건너뛰기
Dexter Corded Belt Sander - 900BS2.5 Motor Replacement
필요한 것
  1. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement, Unplug: 1 단계, 이미지 1/1
    • Before you begin, remember to disconnect the mains plug.
  2. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: 2 단계, 이미지 1/3 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: 2 단계, 이미지 2/3 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: 2 단계, 이미지 3/3
    • Remove the handle, by unscrewing the screw.
  3. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: 3 단계, 이미지 1/2 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: 3 단계, 이미지 2/2
    • Pry the tape off.
  4. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: 4 단계, 이미지 1/1
    • Unscrew the 4 screws.
  5. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: 5 단계, 이미지 1/2 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: 5 단계, 이미지 2/2
    • Remove the belt, then unscrew the screws of the shell to gain access to the motor.
    • Collect the belt to place it in the new room.
  6. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: 6 단계, 이미지 1/3 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: 6 단계, 이미지 2/3 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: 6 단계, 이미지 3/3
    • Remove both accessories.
  7. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: 7 단계, 이미지 1/2 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: 7 단계, 이미지 2/2
    • Remove the screws from the hull in order to have access to the interior and allow the carbon brushes to be blocked.
    • Relax the small metal strip to be able to separate the carbons.
    • Replace the new part in its housing.
  8. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: 10 단계, 이미지 1/2 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: 10 단계, 이미지 2/2
    • Open the cap of the new part to replace the belt.
    • Tighten the inner screw.
  9. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: 11 단계, 이미지 1/1
    • Tighten the four screws.
  10. Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: 12 단계, 이미지 1/3 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: 12 단계, 이미지 2/3 Dexter Corded Belt Sander - 900BS2.5 Motor Replacement: 12 단계, 이미지 3/3
    • Replace the tip, band and handle.
결승점
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
HelloMacOS님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Céline Chemineau
회원 가입일: 01/29/20
16,581 평판
안내서 95개 작성하였습니다
Leroy Merlin Leroy Merlin 회원
Community
36 회원들
안내서 239개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 10
전체 시간: 117
