주요 콘텐츠로 건너뛰기
Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System
필요한 것
  1. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System, Unplug: 1 단계, 이미지 1/1
    • Before starting, remember to disconnect the outlet from the mains.
  2. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: 2 단계, 이미지 1/3 Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: 2 단계, 이미지 2/3 Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: 2 단계, 이미지 3/3
    • Remove the handle, unscrewing the screw
  3. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: 3 단계, 이미지 1/2 Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: 3 단계, 이미지 2/2
    • Remove the strip by leverling
  4. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: 4 단계, 이미지 1/1
    • Remove the front cover to have more space.
  5. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: 5 단계, 이미지 1/1
    • Remove the two screws on the shell.
  6. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: 6 단계, 이미지 1/1
    • Turn the machine over and unscrew the large screw.
    • Unscrew the orange wheel to be able to lift it.
  7. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: 8 단계, 이미지 1/1
    • Remove the spring from the old part to put it back on the new one.
  8. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: 9 단계, 이미지 1/1
    • Put the spring back.
    • Tighten the orange wheel.
  9. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: 11 단계, 이미지 1/1
    • Put the two screws back on the side and the large screw.
  10. Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: 12 단계, 이미지 1/3 Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: 12 단계, 이미지 2/3 Dexter Wired Belt Sander - 900BS2.5 Centre Belt Replacement System: 12 단계, 이미지 3/3
    • Replace the tip, strip and handle.
결승점
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
HelloMacOS님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Céline Chemineau
회원 가입일: 01/29/20
16,581 평판
안내서 95개 작성하였습니다
Leroy Merlin Leroy Merlin 회원
Community
36 회원들
안내서 239개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 13
전체 시간: 307
